Problem PG::ConnectionBad when merging two forums despite several previous successes
User McFly reports a PG::ConnectionBad error when attempting to merge two Discourse forums using the bulk import script, despite previous success. The error stems from the script failing to properly load the PostgreSQL port (5432) from the database configuration. cocococosti identifies the root cause in the discourse_merger.rb script, where the port is assumed to be present in the config but isn’t. They provide a workaround: manually specifying port: 5432 in the connection line. McFly confirms the fix works and admits overlooking the port specification. pi88 asks if the entire process can be automated via cron, to which McFly responds that since merging is typically a one-time operation, automation may not be necessary. The full procedure for merging forums is also shared, based on prior documentation and testing. McFly includes detailed steps covering DB creation, backup extraction, dependency installation, and script execution — all aimed at helping others avoid the same issue.
Hello,
Having already done a merge of two forums in April, on a test server, which went very well. We decided to merge the two forums for good.
Following my procedure of the time, I find myself with a connection error to Postgres, when launching the merge script.
I’ve been at it for four days now, but not being a developer, I’m a bit limited in finding the problem.
Thanks for advance
Here is the error:
discourse@serveur-app:/var/www/discourse$ IMPORT=1 DB_NAME=copyme DB_PASS=passwdDB SOURCE_BASE_URL=http://old.forum.fr UPLOADS_PATH=/var/www/discourse/public/uploads/default bundle exec ruby script/bulk_import/discourse_merger.rb
Loading application...
Traceback (most recent call last):
	5: from script/bulk_import/discourse_merger.rb:817:in `<main>'
	4: from script/bulk_import/discourse_merger.rb:817:in `new'
	3: from script/bulk_import/discourse_merger.rb:22:in `initialize'
	2: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/pg-1.4.2/lib/pg.rb:69:in `connect'
	1: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/pg-1.4.2/lib/pg/connection.rb:661:in `new'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/pg-1.4.2/lib/pg/connection.rb:708:in `connect_to_hosts': could not match 0 port numbers to 1 hosts (PG::ConnectionBad)
I take this opportunity to put the complete merger procedure.
This procedure is based on the original post and the problems encountered during my tests
This procedure worked in April (see this topic).
  • Start with updated backups of the two forums,
  • Install a discourse,
  • Import the two backups,
  • Restore the forum to keep.
In SSH :
  • Go to the /var/discourse folder
  • Enter the app ./launcher enter app.
Create the DB.
su postgres
psql
CREATE DATABASE copyme ENCODING='utf8';
Change the password of the postgres user
\postgres password
Exit postgres
\q
Exit the postgres user
exit
Switch to the discourse user
su discourse
OLD forum save decompression
Go to the latter folder cd public/backups/default
Extract the OLD backup via the command tar xvzf old.forum.tar.gz
Copy from BDD.lu to BDD copyme.
gunzip < dump.sql.gz | psql -d copyme
Exit user discourse
exit
Dependencies
nano, sqlite3 and mysql2 dependencies
(with root user in /var/www/discourse)
apt update && apt upgrade -y
apt-get install -y nano sqlite3 libsqlite3-dev mariadb-server libmariadb-dev -y
gem install sqlite3 mysql2
ruby bbcode to md
git clone https://github.com/nlalonde/ruby-bbcode-to-md.git
cd ruby-bbcode-to-md/
gem build ruby-bbcode-to-md.gemspec
gem install ruby-bbcode-to-md-*.gem
cd ./..
Installing Tiny_tds
You have to install FreeTDS then Tiny_tds.
For FreeTDS:
wget http://www.freetds.org/files/stable/freetds-1.3.12.tar.gz
tar -xzf freetds-1.3.12.tar.gz
cd freetds-1.3.12
./configure --prefix=/usr/local --with-tdsver=7.3
make
make install
For Tiny_tds :
gem install tiny_tds
cd ./..
The script
su discourse
bundle config unset deployment
IMPORT=1 bundle install
Translated with www.DeepL.com/Translator (free version)
Hi,
Postgres does use port 5432 (check via \conninfo in psql command), but I’m afraid in the connection.rb file it calls port 5433.
The password is good checked with the command psql postgres://postgres:password@127.0.0.1:5432
Can anyone confirm that there is no error in the port?
Thanks in advance
I got the same error. Seems like the port is not being loaded in the DB configs here: discourse/script/bulk_import/discourse_merger.rb at main · discourse/discourse · GitHub
If you run that from a rails console:
[1] pry(main)> ActiveRecord::Base.connection_db_config.configuration_hash
=> {:prepared_statements=>false,
 :adapter=>"postgresql",
 :database=>"discourse_development",
 :min_messages=>"warning",
 :pool=>5,
 :timeout=>5000,
 :checkout_timeout=>5,
 :advisory_locks=>false,
 :host_names=>["localhost"],
 :variables=>{}}
The port is not in the config, but the code assumes it is: discourse/script/bulk_import/discourse_merger.rb at main · discourse/discourse · GitHub
While this is fixed in core, you can put the port manually, so instead of
 @raw_connection = PG.connect(dbname: local_db[:database], host: 'localhost', port: local_db[:port], user: 'postgres', password: db_password)
use:
@raw_connection = PG.connect(dbname: local_db[:database], host: 'localhost', port: 5432, user: 'postgres', password: db_password)
Thnaks thanks thanks
I tryed with port = 5432 but not port = 5432
by dint of having our head in the handlebars we miss things
thanks again
Thanks @McFly for putting together a complete guide. This is helpful. Can all of these steps be automated? And create a cron job for it?
Hello,
Knowing that normally this is not a stain that must be repeated I don’t know if it would be useful.
