プラグインなしでカスタムクエリを定義できますか?
I’d like a way to define a query (similar to hitting /latest?max_posts=1) that I can define. Is there any way to accomplish this without using/creating a plug-in?
I’m on a hosted site which doesn’t allow adding custom plug-ins or accessing advanced plugins (such as data explorer), so this solution would all need to be within core functionality.
I’m trying to find all topics that don’t have a reply from trust level_4 users while ignoring certain topics within categories or with tags.
I realize this is likely a big ask to stay within core fuctionality, and will likely require a plug-in to solve, but I figured I’d ask the question.
This would definitely require the Data Explorer plugin.
こんにちは!この件について何か更新はありますか?プラグインを使わずにトピックを日付でクエリしたいと考えています。よろしくお願いいたします。
