מחיקת חשבון ה-admin, לאחר שהרישום הראשון נכשל ובניית האפליקציה מחדש
סיכום מבוסס בינה מלאכותית
The user, powerfeatherdev, encountered an issue during Discourse installation where the admin account creation failed due to a misconfigured email service (Brevo). After fixing the SMTP settings and rebuilding, they were unable to create a new admin account because the username was already taken. Arkshine suggested using the /finish-installation/confirm-email URL to resend the activation email, which resolved the issue. The user then wanted to delete the failed admin account and change the email to a new one. Arkshine clarified that no changes to app.yml were needed; instead, the user could simply click the confirmation email, log in, and update the email in the user preferences. powerfeatherdev initially thought changing app.yml was necessary to access admin privileges with the old email, but Arkshine explained that the correct approach was to use the confirmed email to log in and update the email directly.
Hello, I tried installing Discourse on a VPS using these instructions.
I tried adding the admin account in Step 9, and get to the part where a confirmation e-mail is supposed to be sent. This step failed due to some misconfiguration of the mail service I use (Brevo), which I have corrected.
I rebuild, which succeeds. However, when I try to create the admin account again, it won’t let me, saying username ‘must be unique’. I assume this is due to the first time it was created, but failed in the email confirmation step.
How should I go about solving this issue?
Hi, welcome! :wave:
Did you try going back to the /finish-installation/confirm-email URL and then clicking on “Resend Activation Email” to see if it will work?
Hello, this worked. I can’t believe I hadn’t thought of this :facepalm: I was able to verify that my corrections to the SMPT worked, since I can now recieve the email.
That being said, I would really like to delete the unsuccessfully registered admin account first if possible, since I also change the admin email to a different one.
If you can access the old email, I would change the email in the user’s preference; this seems easier. What do you think?
Ok, so I’ll edit the app.yml to the old email, rebuild, confirm email (I haven’t clicked the confirmation email yet, just tested resending it per my previous post), and just change the email from old to the new one once I have access to the admin panel. Is this roughly what you are suggesting?
Unless I misunderstand, you have nothing to change in app.yml.
If you got the confirmation email (now the settings are fixed), click on it.
Then, go to the user’s preference, and change its email to the new one you want.
The reason I thought I needed to change app.yml is because if I logged in with the old email, it wouldn’t have admin privileges, since app.yml contains the new one. So I was thinking I need to first change app.yml to the old email, then rebuild.
