Destroying a users session via api
The discussion revolves around destroying a user’s session via API. mb450 is trying to log out a user from the forum after they log out of the main website, but is encountering a 302 redirect issue when sending a DELETE request via curl.
mpalmer suggests checking the redirect location and app logs, which mb450 provides, showing a redirect to the forum’s root URL.
mpalmer explains that the redirect is expected behavior and suggests adding an X-Requested-With: XMLHTTPRequest header to suppress the redirect and get a successful response.
mb450 thanks mpalmer and plans to try the solution, later confirming its success in post 6.
Hi,
I need to destory a session for a given user. (Using sso at the moment) but my users can logout of my main website but I want them to be able logged out of the forum at the same time.
Here’s what I’ve tried (cut down test)
   $ch = curl_init();
            curl_setopt($ch, CURLOPT_URL, 'https://forum.blah.com/session/admin1?api_key=<blah blah blah>=&api_username=system');
            curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
            curl_setopt($ch, CURLOPT_HEADER, 1);
            curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
            curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "DELETE");
            $response = curl_exec($ch);
            var_dump($response);
I get a 302 redirect ever time.
But if I do a delete from postman with the same url it works perfectly…
What am I missing?!
Where do you get redirected to, and what do the app logs say about the request?
Hi Matt, thanks for the reply.
I’ve change the domain to forum.blah.uk but here’s the response otherwise unchanged:
HTTP/1.1 302 Found\r\n
Server: nginx\r\n
Date: Tue, 06 Sep 2016 22:45:27 GMT\r\n
Content-Type: text/html; charset=utf-8\r\n
Transfer-Encoding: chunked\r\n
Connection: keep-alive\r\n
X-Frame-Options: SAMEORIGIN\r\n
X-XSS-Protection: 1; mode=block\r\n
X-Content-Type-Options: nosniff\r\n
X-Discourse-Username: system\r\n
X-Discourse-Route: session/destroy\r\n
Set-Cookie: _forum_session=OERYWXRwYzlOY015T0lsT1ZJTzFKUlgwMnp3U2Uyd21lU1FXM3d5d0pzbXBXbXZUaDhzSG9QUFRUSi9iVlRaamNOS1I0bkExTzNqRzZEcWowVVl6S2c9PS0tbXNwR2p1aVJpZENHcVZ1V2plWmhNQT09--3e85c9bbc1ba07ef0131817b2576c9b4bbdaf1f2; path=/; HttpOnly\r\n
X-Request-Id: 16368f90-e840-4c55-8e66-7a4bb600c5b3\r\n
X-Runtime: 0.048811\r\n
Strict-Transport-Security: max-age=6912000\r\n
X-UA-Compatible: IE=edge\r\n
\r\n
HTTP/1.1 404 Not Found\r\n
Server: nginx\r\n
Content-Length: 0\r\n
X-Request-Id: cf4a6822-f53d-4360-8250-b0a94bb924de\r\n
X-Runtime: 0.022277\r\n
\r\n
Can’t see anything in the error logs :persevere:
Looking at the code, the redirect is actually expected behaviour… sort of:
def destroy
  reset_session
  log_off_user
  if request.xhr?
    render nothing: true
  else
    redirect_to (params[:return_url] || path("/"))
If you add an X-Requested-With: XMLHTTPRequest header to your request, that’ll suppress the redirect, and you’ll get an empty-body 200 OK instead.
Cool I’ll give it a go.
Thanks
@mpalmer you sir are a legend
