I did a system upgrade from 14.04 to 16.04 and it seems that after that my system is broken. Trying to start discourse with sudo ./launcher start app gives the following:
Device “docker0” does not exist.
Cannot connect to the docker daemon - verify it is running and you have access
root@DOMAIN:/var/discourse# sudo apt-get install docker
Reading package lists... Done
Building dependency tree
Reading state information... Done
docker is already the newest version (1.5-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Did apt-get remove, apt-get install for docker and docker-engine. Getting some weird message about error initializing graphdriver: driver not supported.
That is a wicked out-of-date version of Docker. We recommend always keeping Docker up-to-date, and they’re up to 1.12.5 now.
Yeeeeeah… newer versions of Docker suck about maintaining compatibility. You were probably using aufs before, so try adding -s aufs to your DOCKER_OPTS (in /etc/default/docker), or wherever they’ve moved that to in the Brave New World of systemd. Making sure you’ve installed the extras kernel package for the aufs.ko kernel module will help, too.
Alternately, yeah, you could nuke /var/lib/docker (with docker-engine uninstalled) and then install docker-engine again, that’d work. You’ll need to do a full rebuild afterwards to get Discourse going again, but as long as you don’t touch /var/discourse, your database, etc should remain intact.
Well, I edit /etc/default/docker and add it to the DOCKER_OPTS line, but I don’t know if systemd respects that file, or if there’s some other magical way of making it happen in systemd fairyland. I’d be surprised if a quick Google search couldn’t help you out, though.
For a given service foo, the package would provide /lib/systemd/system/foo.service. You can check its status using systemctl status foo, or view its logs using journalctl -u foo. To override something in the definition of foo, do:
sudo systemctl edit foo
This creates a directory in /etc/systemd/system named after the unit, and an override.conf file in that directory (/etc/systemd/system/foo.service.d/override.conf). You can add or override settings using this file (or other .conf files in /etc/systemd/system/foo.service.d/).
Did this, but I can’t find any DOCKER_OPTS line here…
cat /lib/systemd/system/docker.service
[Unit]
Description=Docker Application Container Engine
Documentation=https://docs.docker.com
After=network.target docker.socket
Requires=docker.socket
[Service]
Type=notify
# the default is not to use systemd for cgroups because the delegate issues still
# exists and systemd currently does not support the cgroup feature set required
# for containers run by docker
ExecStart=/usr/bin/dockerd -H fd://
ExecReload=/bin/kill -s HUP $MAINPID
# Having non-zero Limit*s causes performance problems due to accounting overhead
# in the kernel. We recommend using cgroups to do container-local accounting.
LimitNOFILE=infinity
LimitNPROC=infinity
LimitCORE=infinity
# Uncomment TasksMax if your systemd version supports it.
# Only systemd 226 and above support this version.
TasksMax=infinity
TimeoutStartSec=0
# set delegate yes so that systemd does not reset the cgroups of docker containers
Delegate=yes
# kill only the docker process, not all processes in the cgroup
KillMode=process
[Install]
WantedBy=multi-user.target
This is then replaced by the file in /etc/… but I have no idea how to add DOCKER_OPTS…
Well, I’m running a DigitalOcean droplet and I just did a dist-upgrade…
I’m at lost here. I was supposed to get to sleep 4 hrs ago and by trying to do a “quick update” to the forum I’ve managed to get 4 hrs of downtime and I’m really, really tired.
I’ll just leave the forum down and try to fix this tomorrow…
Some older DigitalOcean droplets don’t do kernels the normal way. You need to play silly-buggers to upgrade your kernel. Get yourself running the correct kernel, install the extras kernel package, and then see where that gets you.
