I am not sure if I could the problem clear but I will try my best.
I set up the Discourse on port 9988 and proxy it to subdomain, http://d.abc.com/, with nginx. It works. However, I can still access it from http://abc.com:9988/ and http://d.abc.com:9988/. How can I completely disable the access to the port?
I am using Digital Ocean droplet and both top and subdomain are on the same droplet.
Below is my conf for both sites (in one file).
server {
listen 80 default_server;
listen [::]:80 default_server ipv6only=on;
server_name fuguo.uk; # Replace with your domain
location / {
root /var/www/abc.com;
index index.html index.htm;
server {
listen 80;
server_name d.abc.com # Replace with your domain
location / {
proxy_pass http://localhost:9988;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_buffering off;
Many thanks.
