Forcing access to Discourse via domain name only
Hi everyone. So I have setup Discourse and configure Cloudflare and SSL connection.
So far so good. Now I see my website is accessible via the domain name and the default ip, which I do not want.
When I use a CMS such as Wordpress or Modx ( on apache ), I normally configure the ht.access to do the trick. But Discourse is not on Apache…
Is there a way to do that with Nginx ? I am not even sure that Discourse uses it.
Anyway that is the code I would be using:
# Tells the browser to always force SSL.
# Do not use this line if there is a chance you will turn off SSL
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
if ($scheme != "https") {
	rewrite ^ https://discourse.mydomain.com$request_uri permanent;
if ($host != "discourse.mydomain.com") {
Any suggestions ?
Thanks
Still haven’t find a simple way to do it.
If anyone has a solution I’d be grateful :slightly_smiling_face:
It sounds like your question is something like:
host:port at 123.123.123.123:8080
domain example.com maps to host:port
you don’t want requests for host:port to work, but only requests for the domain that are mapped to the host:port
But that doesn’t make sense to me and the code example you posted isn’t about that so I am confused.
What instructions did you follow for your install and is this a domain name, host IP, or port problem?
Really sorry I didn’t make myself clear.
Let say my website is hosted on the ip: 123.123.123.123
And this is my domain name: forum.example.com
Right now, visitors can browse the forum by accessing the ip 123.123.123.123
What I want is:
When someone goes to the ip, it will be redirect to forum.example.com
The issue is that I am not able to locate ngnix default file.
Enable https. Run disourse-setup again and give your email address for the let’s encrypt question.
