Disable Discobot Tutorial Certificate
Due to the reported bug within the tutorial cert of Discobot [ Discobot Certificate Issues [title, public access, user id information leak] ] we want to disable the certificate and/or the access to it.
I’ve tried disabling discobot, but the certificate is still created.
Does anyone knows a setting and/or have a hint to where have a look?
I’m quite sure I could disable it within the docker container, but I really want to avoid that.
Thanks in advance!
Not possible at the current time. We don’t view this as a critical problem, so you may need to wait a day or two.
Allright, thanks nevertheless!
