Hi,
I am hosting Discourse on a VPS with 1GB memory.
I had some issues installing it initially because although it has 1GB installed the environment reports just under 1GB (991448 kB available). I modified the install script to hard code the memory check at 1GB.
It runs just fine and and I don’t have any issues but I am getting spammed daily with ‘Problems have been found’ messages due to Admin panel reporting ’ * Your server is running with less than 1 GB of total memory. At least 1 GB of memory is recommended’.
Is there a way I can disable the message?
