בטל PWA
How can I disable the PWA option on my communities?
We create our own apps for our communities and don’t want users getting confused.
Furthermore, is there a way to know how many people have downloaded the PWA?
Thanks!
Try uploading a .jpg file to the manifest icon site setting, then browsers won’t show the install button anymore.
Thanks @Kuro22! I’ll give it a go :slight_smile:
That worked! Thanks! Now to just find out how many people downloaded the PWA…any ideas?
Also wonder if there’s a way to get that number :thinking:, though seems impossible…
