Sei que é fácil contornar, mas estou trabalhando com um grupo de fotógrafos profissionais que não querem que suas imagens sejam facilmente baixadas, e eles estão exigindo que o clique direito seja desabilitado para as imagens. Alguma ideia de como conseguir isso?
A common non-tech-savvy approach. You could use JavaScript to disable right-click. But IMHO you would do better to explain to them why doing so would be futile.
i.e. there are two ways to protect content
- don’t put it online (always works without fail)
- take legal action (too often cost prohibitive for most)
I completely understand that, but if there is a way to do it just to please them it would be much easier.
I have found this script to disable right click globally, but it would be so much nicer to have it only on the lightbox or just images
<script type="text/javascript">
function click (e) {
if (!e)
e = window.event;
if ((e.type && e.type == "contextmenu") || (e.button && e.button == 2) || (e.which && e.which == 3)) {
if (window.opera)
window.alert("");
return false;
if (document.layers)
document.captureEvents(Event.MOUSEDOWN);
document.onmousedown = click;
document.oncontextmenu = click;
</script>
You could do it with some CSS, but I generally don’t think it’s going to save anyone much angst. If I want to steal your image without paying for it I either
- Know how to circumvent a block
- Have zero value to you regardless
If you must:
.cooked img {
pointer-events: none;
.image-source-link {
display: none;
This will prevent right clicks on images in posts. You can still right click, but it passes through the element to the background (so no image options). Lightboxes and other things (voting, for example) still work. .image-source-link is the download option in lighboxes.
I think you could also make it so users have to use a class when they upload images, and have the style above only apply when that class is added. For example, they could use a data-theme attribute to post
<div data-theme-image="block">
<img src=""/>
</div>
And you’d add this to your CSS
[data-theme-image="block"] img {
Thanks Kris, turning off the pointer events is not ideal since I still want the pointers, just no right click.
I found this script which works brilliantly on the smaller image in the post, but not the lightbox. Any ideas on how to modify this to make it work in the lightbox as well?
$(document).ready(function(){
$("img").bind("contextmenu",function(e){
return false;
</script>
It seems as though this should work to target the lightboxed image, but it does not. Any ideas why?
$(".mfp-img").bind("contextmenu",function(e){
return false;
Sorry, lost track of this and just noticed your marketplace post
Does this work for you when added to /head?
const TopicRoute = require("discourse/routes/topic").default;
TopicRoute.reopen({
activate: function() {
this._super();
Em.run.next(function() {
$('body').on('contextmenu', '.cooked img, .mfp-img', function(e){ return false; });
</script>
Thanks Kris, it works on the thumbnail, but not the lightboxed image
Ah right, I forgot a class for the lightbox too — I updated the code above.
You’re my hero, thank you Kris!
