Disabling mailing list mode does not update user settings
The discussion revolves around a bug where disabling mailing list mode in admin settings does not update existing user notification settings, which remain in mailing list mode. jnns reports that users who previously enabled mailing list mode retain this setting even after the admin disables it, and digest mode is also affected. codinghorror questions the expectation, arguing the admin setting only applies to new users. tophee supports this view, noting the admin option should clarify if it only affects new users. techAPJ claims the issue cannot be reproduced, stating that disabling mailing list mode removes the option for all users and stops mailing list emails, and advises checking if ‘disable digest emails’ is enabled.
If a user enabled mailing list mode in their user settings and an admin disables mailing list mode per admin settings, this change seems not to have an effect on the user notification settings (which are still set to “mailing list mode”).
Additionally, this leads to digest mode being disabled for this user as well.
Using Discourse v1.8.0.beta13 +18.
3 Mi Piace
Why would you expect it to behave this way? The admin setting simply removes the choice for all future users, not all prior history..
There are two admin settings:
[ ] disable mailing list mode
Disallow users from enabling mailing list mode.
and
[ ] default email mailing list mode
Send an email for every new post by default.
I would also expect that if I disable the first one, no user would would be able to have mailing list mode enabled any more. If it only turns off mailing list mode for new users, I would expect it to say so in the help text, i.e. “Disallow new users from enabling mailing list mode.”
3 Mi Piace
I am not able to repro this. In my testing enabling “disable mailing list mode” setting removes the “Mailing list mode” section from /u/techapj/preferences/emails and disables sending of mailing list emails for all the users.
Can’t repro this either. Make sure “disable digest emails” setting is disabled.
3 Mi Piace
