Discourse API-Berichte
Hello!
I am trying to use the reporting functionality found in the Discourse api via a node app on a different server.
When I issue my requests (whether on the server or in postman) I get a 404 that the url was not found?
Is this function depreceated or still around? Can’t seem to figure it out.
http://docs.discourse.org/#tag/Reports%2Fpaths%2F~1page_view_total_reqs%2Fget
Do we need to rebuild the docs.discourse.org site @blake?
No the doc site is working just fine, but the url for that endpoint may have been documented wrong :blush:.
@jordan1909 can you try hitting this endpoint on your site?
Looks like you will need to include /admin/reports and all correct params
@blake
So this works in my browser but I need to get the JSON data back for usage elsewhere and everytime I issue the query anywhere else I get a raw dump of the page?
Any idea what I’m missing? Issuing a GET request here.
Postman URL
Try adding .json to the end of the URL
@david
I :heart: you
I had previously marked this as solved however if I execute the request via Postman or in an Ajax query I am getting a 404. Is this available to the api for external calls? Am I missing something?
Does anyone have an example of getting this value via an Ajax request or even Postman?
Are you including an API key in your postman request?
@david
Clearly I have been staring at my screen too long. :man_facepalming:
I take it the value is api_key not ap_key.
I’ll go hide in the corner and think about what I’ve done.
