Discourse blocking with password reset
Socioneers reported issues after importing 45,000 users to a Discourse installation and sending invitation links via a separate mailing program. Approximately 40 users could not reset their passwords during registration, and admins received 422 errors when attempting manual resets. codinghorror requested log details. Socioneers revealed that the browser inspector showed an error message in Dutch stating the action was performed too often, accompanied by login delays. Server logs indicated a Circular dependency detected while autoloading constant PasswordValidator exception, and Sidekiq restarted multiple times due to excessive memory consumption. After an update and rebuild, the issues persisted. Socioneers also noted a 422 Unprocessable Entity error for failed resource loads. The issue was ultimately resolved by Socioneers, who identified that all requests originated from the same IP address, triggering rate limiting. They referenced related discussions on ramping up and performance issues and running other websites on the same machine.
We imported a group of 45.000 users on a discourse installation and send them an invitation link with a separate mailing program. After activating and password resetting about 300 users about 40 people could not reset there password during the registration procedure. We admins tried to reset them via the admin panel, but we got 422 error messages.
Who knows what goes wrong? Something in Sidekiq?
Cheers,
What shows up in /logs in your browser when logged in as admin? Any errors?
Thanks!
Inspector shows:
{errors: ["je hebt deze actie te vaak uitgevoerd, probeer het later nog eens."]}
errors
In english: you executed this action to often, try it later again.
We get this same message when you file a request at the site login page.
Additionally when we try to login we get a message that we have to wait to login
At 12 am we had this error in log> Job exception: Circular dependency detected while autoloading constant PasswordValidator
And Sidekiq has restarted a couple of times I yesterday en tonight consuming to much memory.
We had an update and a rebuild but we have still the same problems, is there a cap on the amount resets you can do?
Cheers
and this error: Failed to load resource: the server responded with a status of 422 (Unprocessable Entity)
Resolved, everything went over the same ip
See here:
https://meta.discourse.org/t/ramping-up-and-performance-issues-related-to-scalability/50246/8
and here:
