It’s still not working, how do I configure Discourse SSL to enable it?
The email supports SSL
Why can’t SSL connect?
Is it not connecting?
Your authentication setup is correct, and the mail you’re receiving is the same job, over and over again.
Discourse gets through the whole mail sending process but after receiving an unknown response code it aborts, thinking the mail send failed.
But the mail server actually did accept the mail!
Since Discourse didn’t realise the send was actually successful, it reschedules the job over and over.
I changed my email, configured START_TLS to true.
It’s normal now!!!
But disabling DISCOURSE_SMTP_ENABLE_START_TLS: false
and using SSL to test sending emails doesn’t work, why? How to configure Discourse to enable SSL?
For port 587 you should using STARTTLS
But disable DISCOURSE_SMTP_ENABLE_START_TLS: false
Port 465, using SSL, test sending emails fails, why? How to configure discourse to enable SSL
Your configuration in this post, if it’s the same one that generated this traceback, is correct. Use that one (port 587, and STARTTLS).
Port 587 is for TLS encryption negotiated after the initial connection (STARTTLS), whereas
Port 465 is for TLS encryption at connect time (SSL/TLS).
But many providers (correctly) block port 465 because of historical reasons, so 587 is recommended.
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_ENABLE_START_TLS: true
This configuration problem still cannot be solved ![]()
Let’s still use port 587, port 465 has many issues
QQ Mail won’t work, using Mailgun can solve the problem.
FYI, as of this change the error message received should be displayed in the logs.
