Discourse Calendar updated to use fullcalendar 6
Discourse calendar received a significant update today :rocket:. The core of the update is migrating from fullcalendar 4 to fullcalendar 6 which will bring us an updated UI:
We also used this opportunity to make the following changes:
  • Clean URLs for upcoming events page, eg: /upcoming-events/day/2025/8/2
  • Post event preview on click over an event
  • Performance has been vastly improved and having a large number of events should now be possible.
  • We now rely on the css variables provided by fullcalendar which should make the calendar work with your theme out of the box.
Bravo, great job, thank you very much :heart_eyes:
Small question, can we set (year) as the default for the mobile part?
Otherwise, once again, it’s great!!
Thank you for the work ! Is both US/EU date format system supported for those url? and what if there are several events on the same day?
Sorry we will support only one url format for now.
That doesnt prevent you to see all the events on this day/month/year. If you want to link to an event directly, link to the post event.
Indeed the direct link to the event can be shared and providing multiple url format is not an easy task. We are already thankful that you are providing us with this update to fullcalendar 6 with new features !
Since the upgrade I’m seeing instances of a 1 hour difference between the topic post time (correct) and the calendar display time (one hour earlier) on some events, but not all.
This either resolves after our local time zone switches to summer time or throws out some other events (in reverse) after daylight saving starts. Not all events are affected however. Is this a known issue? Is there a fix in the pipeline?
Contribute > Bug
This is brilliant! It really lifts the calendar to the next level.
I notice that the text of the event titles doesn’t wrap in the (default) Month view. Is this intentional?
Desktop Calendar
It would be nice to see the whole titles in the Month view on desktop (?perhaps on hover), as these are often packed with useful information. Of course, that would mean that the events could get greedy and take up more space.
Mobile Calendar
Also, in mobile it is rare to see more than the time. I guess this doesn’t matter so much as it is easy to tap them to see more.
An agenda view?
Lastly, it would be super helpful to have an agenda view, which is a common way of representing events. Is this at all possible via the calendar?
I know that it is doable using the Right Sidebar Blocks, but that is in a different context.
Yes I will be fixing this today, Im trying to have a definitive repro, thanks.
Should have been fixed by: FIX: removes support for include_expired param (#34582) · discourse/discourse@249ae00 · GitHub
I have a small suggestion:sweat_smile:
Instead of going to today’s date, wouldn’t it be better to go directly to the date of the next event?
It’s just an idea! :innocent:
I think it’s generally expected to open today. I you need to link your users to a specific day you can just craft the link you want now: /upcoming-events/day/2025/9/2
Thank you!
Would following ISO date format be possible? As in YYYY/MM/DD (two digits for months and days)?
Im mostly following what google is doing here:
Screenshot 2025-08-28 at 15.47.18
Ah, why would they follow standards when they can break it and create more work for others. :person_facepalming:
Struggling to understand why /day/2025/09/01 is so much better than /day/2025/9/1
I would argue it is worse to add the zeros cause it takes up more space in the bar.
It isn’t better. Just more standardised, and consistent with how dates are encoded in other parts of Discourse.
On the converse, the way it is currently implemented is consistent with Discourse URLs (which need to have open-ended numbering).
So, this is a philosophical decision. Internal consistency with URLs or internal/external consistency with dates. There are pros and cons for each. I prefer the current implementation.
If I would start write that date the form would be mm/dd. Because it is a standard practically everywhere — except when connection is from US and they would drop leading zeros and and start words with capital letters :smirking_face:. Or from coders who count spaces, because even americans can read and use mm/dd.
So, it is matter of muscle memory and a factoid that most of the word is used to use ISO format and it is hard to remember which software and platform uses which format. That is one of those questions where always someone loses — the question is which group is the biggest.
Ha! Sorry I didn’t want to bikeshed. Pure numbers are sorted numerically, leading zeroes make months and days appear in the correct order.
I’m still seeing errant behaviour of recurring events before and after local time changes to daylight saving time. We are on a hosted plan, so is it just a matter of waiting for the fix to be pushed through?
