How do I add category banners?
How woud i achieve something like that?
https://gyazo.com/973b2e2525e43beeb9000b67bbae803e
When i add pictures to my Category they are all shrunk and ugly.
is there a custom plugin or something?
2 curtidas
Have a look at Category Banners. It is a theme component that you can install on your site to add a banner to your categories. The “Additional CSS styling” section at the bottom of the topic gives details about how to set a background image for the banner.
3 curtidas
From the looks of it it seems like thats a banner for the category, i need one that shows the section, to explain myself better…
https://forum.fivem.net/categories
thats what i want
This will require some custom work. Have a look at the theme guide if you want to do it yourself or create a topic in the marketplace category if you want to hire someone to do it for you.
2 curtidas
This is what they use but i can’t get it to work
discourse-misc-html-css (2).zip (2.5 KB)
There are many links and items to edit both in the CSS and in the Head tab , did you do it?
1 curtida
That there is the costom css Fivem uses today and that is what i got sendt from the admin team but i have no idea how to get it to work
So I have been working for a while now on this and I got it working ish
Pic
And it is working great tbh
But at the top, it just duplicates some of the categories for some reason
How can I fix this? and make it not duplicate categories?
Here is my config
discourse-misc-html-css.zip (2.5 KB)
So now I have got it fixed for my self at least
So first of all download this file
So if you are not sure how to add that file to your site then check this guide out first
So in the Misc/HTML+CSS Common and then in CSS You have to tweak some settings
So first you need to copy this line
        &.fivem > .category-list {
        &:before {
            content: 'FiveM';
        background-image: url(https://i.imgur.com/1YZTip0.png);
And then you have to change what you want your banner to be named and
In my example, I’m going to use test1
        &.test1 > .category-list {
        &:before {
            content: 'test1';
And then you are done in the CSS section
Then go over to the section
Then go down to
<script type='text/x-handlebars' data-template-name='components/categories-with-featured-topics'>
And finde the section named
<div class="category-thing fivem">
Then copy
{{categories-only categories=(filter-fivem categories)
                  latestTopicOnly=latestTopicOnly
                  showTopics=true}}
</div>
And change it to your settings in my example I used test1
So I’m going to do the same here
<div class="category-thing test1">
{{categories-only categories=(filter-test1 categories)
              showTopics=true}}
</div>
Then go down to
<script type='text/x-handlebars' data-template-name='mobile/components/categories-with-featured-topics'>
And then find
              showTopics=true}}
</div>
And change it to your settings in my example I’m going to change it from fivem to test1
                  showTopics=true}}
</div>
Then go future down and find the section with this
registerUnbound('filter-core', (categories) => {
   return categories.filter(a => !a.slug.match(/^redm-/) && !a.name.match(/^fivem/i) && !a.read_restricted);
Here you want to add your category flag that we have created future up. Why you want to add this is so you don’t get duplicated categories like the problem I had here
So I’m going to add test1 for my example
   return categories.filter(a => !a.slug.match(/^redm-/) && !a.name.match(/^test1/i) && !a.name.match(/^fivem/i) && !a.read_restricted);
Then go down and find the section named
registerUnbound('filter-fivem', (categories) => {
   return categories.filter(a => a.name.match(/^fivem/i));
Here you want to change out fivem to what you want again so in my example I’m going to add test1
registerUnbound('filter-test1', (categories) => {
   return categories.filter(a => a.name.match(/^test1/i));
Now what you want to do is to change your Category Slug here is my example
2bf89bcdcb2f897364bb984c82d4e343
And then that category will go under the test1 banner
And all other categories will go under the core CFX.RE banner in this example
Here is btw my settings that I’m using on my site atm
If you want to check it out then here it is
https://forum.tgacommunity.com/
Alos you can mark this topic as solved?
So I hope this helped you guys and if anyone has any questions then just ask me here or on pm
4 curtidas
Olá a todos. O @manuel criou um componente de tema que expande este código e facilita o uso por pessoas em seus próprios fóruns.
Mas ambos os métodos funcionam e cabe a você como deseja fazer. E ambos os métodos dão o mesmo resultado.
1 curtida
