Discourse-doctor šŸ‘©ā€āš•ļø
I wonder if we need to check this or if any log would show this?
Just a reminder that /discourse-setup already checks for basic prerequisites before allowing an install, such as RAM, DISK, CPU, etc
1 curtida
Yes, that’s why I assumed that checking available RAM is not needed. RAM mostly stays the same after installation. But available disk space tends to get smaller with time. I ran into problems with other systems several times which root cause was that the system had no free disk space remaining. So that would be worth checking.
I will create a PR.
Here it is: added available disk space check, moved discourse path into constant by SKoschnicke Ā· Pull Request #2 Ā· jjaffeux/discourse-doctor Ā· GitHub
4 curtidas
Any updates on this?
2 curtidas
I’m taking notes on what I could do each time I see a topic ā€œxxx not workingā€ and will work on it again once I have a better understanding. It’s not dead.
6 curtidas
Would adding a git section give useful information?
git status for example?
2 curtidas
