Disco - Interactive Shell Discourse Management Tool with Telegram Notifications
disco - Interactive Shell Discourse Management Tool with Telegram Notifications
:information_source: Summary A command-line wrapper for Discourse management with interactive menu interface and automatic Telegram notifications for maintenance operations
:hammer_and_wrench: Repository Link GitHub - DigneZzZ/discourse-cli: Discourse CLI interface with TG events when rebuild Β· GitHub
:open_book: Documentation Installation Guide Β· Quick Start Β· Examples
:wave: Introduction
Hey everyone!
I want to share a solution I created while managing my community forum. Like many of you, I have a Telegram group for my community, and I was constantly getting questions about β€œIs the forum down?” or β€œWhen will maintenance be finished?” whenever I needed to update or restart Discourse.
To solve this (and make my life easier), I built disco - a command-line wrapper for Discourse management that includes automatic Telegram notifications and an interactive menu interface.
:dart: What Problem It Solves
  • No more β€œIs the forum down?” questions - automatic notifications to your Telegram group
  • Simplified management - interactive menu instead of remembering launcher commands
  • Safety first - confirmations for dangerous operations (rebuild, stop, cleanup)
  • Better visibility - real-time status, logs, and resource monitoring
  • Faster troubleshooting - all operations in one place with clear output
:sparkles: Features
:video_game: Interactive Menu Interface
Launch disco without arguments to get a beautiful numbered menu:
β•‘  πŸš€ Discourse Manager v1.2.0                        β•‘
β•‘  πŸ“¦ Container: app | Status: 🟒 Running          β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
 1.  πŸ“Š Show Status
 2.  πŸ”„ Restart Container
 3.  πŸ“ View Logs (last 100 lines)
 4.  πŸ“Ί Live Monitor
 5.  πŸ”§ Full Rebuild (with updates) ⚠
 6.  ⚑ Fast Rebuild
 7.  πŸ’Ύ Create Backup
 8.  🧹 Cleanup Docker Resources ⚠
 9.  ▢️  Start Container
10.  ⏸️  Stop Container ⚠
11.  🐚 Enter Container Shell
12.  πŸ“₯ Update Launcher
13.  πŸ“± Test Telegram Notifications
14.  βš™οΈ  Show Configuration
15.  πŸ”„ Update disco
 0.  ❌ Exit
Features:
  • Just type a number (1-15) to select action
  • Real-time container status in header
  • Visual warnings (:warning:) for critical operations
  • Safety confirmations - type β€œyes” to confirm dangerous actions
  • Smart sudo detection - warns when root privileges needed
:iphone: Telegram Notifications
Automatic notifications keep your community informed:
When rebuild starts:
πŸ”§ Forum is going into maintenance
⏱ Expected time: ~10 minutes
We apologize for the temporary inconvenience.
When complete:
βœ… Forum is back online!
⏱ Maintenance time: 7m 57s
πŸ”– Version: 3.2.0.beta4
Thank you for your patience! πŸš€
On errors:
❌ Forum update failed
⏱ Attempt duration: 3m 12s
⚠️ Administrator attention required!
Check logs: disco logs
:bar_chart: Monitoring & Diagnostics
Status Overview:
πŸ“Š Discourse Status
πŸ“¦ Container: app
🟒 Status: Running
⏱  Uptime: Up 3 days
πŸ’» CPU: 2.5%
🧠 Memory: 1.2GB / 4GB
Features:
  • Real-time CPU and memory usage
  • Container uptime tracking
  • Automatic version detection via API
  • Live log monitoring with follow mode
  • Resource monitoring dashboard
:shield: Safety Features
  • Confirmation prompts for critical operations (rebuild, stop, cleanup)
  • Sudo detection - warns when privileges are needed
  • Version display - always know what version is running
  • Detailed warnings - explains exactly what each critical action will do
:zap: Quick Operations
All standard Discourse operations available:
  • Container management - start, stop, restart, enter shell
  • Maintenance - rebuild (full/fast), backup, cleanup
  • Monitoring - status, logs, live resource monitor
  • Updates - launcher updates with one command
:inbox_tray: Installation
Quick Install
# Download and install
curl -o disco https://raw.githubusercontent.com/DigneZzZ/discourse-cli/main/disco
chmod +x disco
sudo mv disco /usr/local/bin/
# Verify installation
disco version
# Launch interactive menu
disco
:gear: Configuration
Basic Setup
Create a configuration file in one of these locations:
  • ~/.disco.env (recommended)
  • /etc/disco/.env
  • Next to the script
# Copy example configuration
curl -o ~/.disco.env https://raw.githubusercontent.com/DigneZzZ/discourse-cli/main/.env.example
# Edit settings
nano ~/.disco.env
Configuration Example
# Basic settings
DISCOURSE_PATH=/var/discourse
CONFIG_NAME=app
# Telegram notifications (optional)
TELEGRAM_BOT_TOKEN=1234567890:ABCdefGHIjklMNOpqrsTUVwxyz
TELEGRAM_CHAT_ID=-1001234567890
TELEGRAM_THREAD_ID=1
Setting up Telegram Notifications
1. Create a bot:
  • Message @BotFather on Telegram
  • Send /newbot command
  • Follow the instructions
  • Save the bot token
2. Get Chat ID:
  • Send any message to your bot
  • Visit: https://api.telegram.org/bot<YOUR_TOKEN>/getUpdates
  • Find "chat":{"id":...} in the response
3. Get Thread ID (for groups with topics):
  • Send a message to the desired topic in your group
  • In getUpdates response, find message_thread_id
4. Test notifications:
disco test-telegram
:rocket: Usage
Interactive Menu (Recommended)
disco
# With sudo for administrative actions
sudo disco
Simply type the number of the action you want to perform!
Command-Line Mode
For automation or quick operations:
# Status and monitoring
disco status                    # Show container status
disco logs                      # View last 100 lines
disco logs 500                  # View last 500 lines
disco monitor                   # Real-time resource monitoring
# Container management
sudo disco start                # Start container
sudo disco stop                 # Stop container
sudo disco restart              # Restart container
disco enter                     # Enter container shell
# Maintenance
sudo disco rebuild              # Full rebuild with updates
sudo disco fast-rebuild         # Quick rebuild (no launcher update)
sudo disco backup               # Create backup (auto name)
sudo disco backup my-name       # Create backup (custom name)
sudo disco cleanup              # Clean up Docker resources
# Utilities
sudo disco update-launcher      # Update Discourse launcher
disco test-telegram             # Test Telegram notifications
disco show-config               # Show disco configuration
disco version                   # Show version
disco help                      # Show help
:page_facing_up: Settings
Name Description Default Required
DISCOURSE_PATH Path to Discourse installation directory /var/discourse No
CONFIG_NAME Container configuration name app No
TELEGRAM_BOT_TOKEN Telegram bot token from @BotFather - No (for notifications)
TELEGRAM_CHAT_ID Telegram chat or group ID for notifications - No (for notifications)
TELEGRAM_THREAD_ID Thread ID in group with topics - No (optional)
:bulb: Use Cases
Community Manager
  • Keep community informed during maintenance automatically
  • No more β€œis the forum down?” questions
  • Professional maintenance notifications
System Administrator
  • Interactive menu for occasional management tasks
  • Safety confirmations prevent accidents
  • Quick access to logs and status
DevOps Teams
  • CLI mode for automation and scripts
  • Consistent operations across team members
  • Easy integration with monitoring systems
:chart_with_upwards_trend: Real-World Impact
Since deploying this tool:
  • :white_check_mark: Zero β€œis the forum down?” questions in our Telegram group
  • :white_check_mark: Faster maintenance operations - no context switching between terminal and messaging
  • :white_check_mark: Fewer mistakes during updates - safety confirmations work!
  • :white_check_mark: Better monitoring - quick access to logs and resource usage
:books: Documentation
:heart: Why I Built This
Managing Discourse through the standard launcher is powerful, but:
  • Commands are hard to remember
  • No built-in notification system for community
  • Easy to make mistakes with critical operations
  • Community members always asking about downtime
disco wraps the launcher with a user-friendly interface and keeps everyone informed automatically.
:handshake: Contributing
Contributions are welcome! If you have ideas or suggestions:
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Submit a Pull Request
Or simply open an issue with your feedback!
:page_with_curl: License
MIT License - completely free to use and modify.
GitHub Repository: GitHub - DigneZzZ/discourse-cli: Discourse CLI interface with TG events when rebuild Β· GitHub
