Discourse doesn't re-verify an address changed by SSO
If a SSO provider sets require_activation=true, users must confirm their E-Mail address after they first sign in with SSO.
When a user changes his E-Mail address in a non-SSO setting, he must verify his address before the change is saved.
When the setting sso overrides email is enabled, and a user changes this E-Mail address in the external system, his address is changed in Discourse without verification, even with require_activation=true. I think that this is inconsistent. I’d expect that in this setting, the account is disabled whenever the address changes, requiring the user to verify his new address.
3 Mi Piace
This seems like a horrible idea for our use case.
Discourse trusts our SSO provider (user directory) enough to authenticate users, so why shouldn’t it also trust that system to validate users’ email addresses?
Our users would become extremely annoyed if they had to validate their email addresses twice on each change.
OK, maybe I misunderstood. I just hope this is not the default behavior.
Correct, this is not about the default behavior. Normally, Discourse trusts the E-Mail address provided. If the SSO payload sets require_activation=true (which shouldn’t be the case for you), it doesn’t trust the address for signups (which is intended), but trusts it for address changes (which this report is about).
1 Mi Piace
you got to opt in with require_activation=true it’s a legit edge case of a bug
5 Mi Piace
I’m running into this when sso overrides email is enabled on Discourse and a user changes their email address on a WordPress site. How big of a security risk is this?
Adding user.active = false to DiscourseSingleSignOn#change_external_attributes_and_override for the case when the user’s email doesn’t match the email sent with the sso request forces the user to confirm their new email address. Unfortunately it does this by redirecting them to users/account_created, so it’s a bit of a hacky solution.
Edit: the problem is that WordPress will let a user change their email without verifying it. The wp-discourse plugin attempts to verify the email on registration, and if it can’t it sets require_activation to true. Possibly the simplest solution is to recommend that sites using the plugin should not enable sso overrides email.
I haven’t tested this, but…
  • If there is an “unclaimed” developer email address in app.yml (rather unlikely to happen), this could allow any user to gain administrative rights.
  • It allows spamming, because you can change your address to an address you want to spam.
  • It might allow taking over a staged account if changing the email address merges the accounts, but I’d assume it doesn’t (and errors out instead).
I don’t see any other risk right now, but user identity is strongly tied to the email address in Discourse, so it’s hard to estimate the impact.
4 Mi Piace
A proper fix for this seems like it could be time consuming. Would it be possible to change the setting’s description to include a warning to not enable it unless the email address is verified by the SSO provider? Or even more specifically, to not enable it with the wp-discourse plugin?
Absolutely, it should have a huge warning, with details.
Sure this is a bug we should fix. I need to add some tests for it.
3 Mi Piace
Just a small update, because I was asked via PM:
The bug is still open in the latest beta release, v1.8.0.beta4 +284 (9fa29ca89815878f768885f7413b8beaae3a414c).
1 Mi Piace
Maybe @sam should add some tests for it?
2 Mi Piace
Did @sam add some tests for it? It seems that this issue still exists.
1 Mi Piace
It is on my list, I have not addressed anything here yet.
5 Mi Piace
I’d like to vote for this as well. Our IdP currently allows users to change their email address without verification, which in 2 steps allows a user to completely hijack an existing Discourse user.
  1. Change the email address to some other existing user, sign on using SSO, it will update the external_id of that user.
  2. Change the email address back, now the external_email of that user is updated as well.
Does it make sense to provide a way of disabling 1)? The external_id of a user should be immutable and the email address should not be used to look up users?
And of course, updating a users email address in Discourse with require_activation=true should send an activation email for that address.
2 Mi Piace
This goes against the requirements set out in the SSO topic:
3 Mi Piace
If Discourse updates the external_id of a user based on their email address, isn’t that violating the requirement itself that external_id will never change? It’s effectively merging two separate external users into one discourse user if their email address is the same.
3 Mi Piace
Hai verificato che questo accada effettivamente? (Secondo la mia comprensione amatoriale del codice, sì.)
Se è così, penso che questo sia un bug di sicurezza (Contribute > Bug) – mentre Discourse dovrebbe abbinare gli utenti tramite email se l’external_id è sconosciuto, non dovrebbe trovare un utente che ha già un diverso external_id e aggiornarlo.
Forse questo codice dovrebbe restituire un errore se l’utente ha già un external_id (diverso) impostato?
3 Mi Piace
This is actually what happens in my installation, the documentation / official SSO howto mentions this. I believe this is contradicting the aspect before that external_id is immutable, if Discourse updates the external_id, if an existing user is found by email address. While this could be desirable because it makes moving users between external systems easier, I see the security risk here as it allows an external system to both change the external_id as well as the email address of existing users, completely disconnecting it from the original external system.
I don’t know the motivation behind this behavior though and do not know if failing in the case that the external_id is already populated is desirable. After all the external fields are not editable by administrators in the front end and thus it would not be (easily) possibly to rectify a misconfiguration.
3 Mi Piace
It is definitely a critical security issue, if sso overwrites external_id, it shouldn’t. But as I understand the code, it should set external_id via match_email_or_create_user only if there have been no user with such external_id found on sso login:
  def lookup_or_create_user(ip_address=nil)
    sso_record = SingleSignOnRecord.find_by(external_id: external_id)
    if sso_record && (user = sso_record.user)
      sso_record.last_payload = unsigned_payload
    else
      user = match_email_or_create_user(ip_address)
      sso_record = user.single_sign_on_record
I’ll be able to check the behavior on my local setup tomorrow.
L’ho verificato e confermo che l’external_id può essere sovrascritto in questo modo. E, in combinazione con il problema di questa discussione, un account può essere dirottato in questo modo. Sono d’accordo con @fefrei che dovrebbe essere aggiunto come un Contribute > Bug separato, rilevante per la sicurezza.
2 Mi Piace
