Guten Morgen/Abend allerseits,
Ich habe kürzlich die Docker-Version von Discourse eingerichtet und versucht, meinen ersten Blogbeitrag mit Hugo in das neu eingerichtete Discourse-Forum einzubetten.
Besonders auffällig ist, dass die Änderungen nicht gespeichert zu werden scheinen, wenn ich „Eingebettete Beiträge kürzen“ und „Importierte Themen sind nicht aufgeführt, bis es eine Antwort gibt“ deaktiviere. Alle anderen Änderungen werden jedoch gespeichert.
Dies wird in production.log protokolliert:
Started GET "/embed/comments?embed_url=https%3A%2F%2F(REDACTED).com%2Farticle%2Fwelcome%2F" for IP-Redacted at 2023-06-09 06:19:00 +0000
Processing by EmbedController#comments as HTML
Parameters: {"embed_url"=>"https://(REDACTED).com/article/welcome/"}
Completed 500 Internal Server Error in 40ms (ActiveRecord: 0.0ms | Allocations: 11449)
ActiveRecord::ConnectionAdapters::PostgreSQL::Quoting::IntegerOutOf64BitRange (Provided value outside of the range of a signed 64bit integer.
PostgreSQL will treat the column type in question as a numeric.
This may result in a slow sequential scan due to a comparison
being performed between an integer or bigint value and a numeric value.
To allow for this potentially unwanted behavior, set
ActiveRecord.raise_int_wider_than_64bit to false.
lib/freedom_patches/fast_pluck.rb:39:in `select_raw'
lib/freedom_patches/fast_pluck.rb:60:in `pluck'
lib/topic_view.rb:378:in `filter_posts_paged'
lib/topic_view.rb:317:in `filter_posts'
lib/topic_view.rb:133:in `initialize'
app/controllers/embed_controller.rb:97:in `new'
app/controllers/embed_controller.rb:97:in `comments'
app/controllers/application_controller.rb:418:in `block in with_resolved_locale'
app/controllers/application_controller.rb:418:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
lib/middleware/anonymous_cache.rb:369:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:228:in `call'
Auf der Discourse-Seite wird das Thema in der richtigen Kategorie erstellt und scheint insgesamt korrekt zu sein, mit Titel und Autor, wie unten zu sehen ist. Aber der Aufruf der Embed-Seite ergibt einen 500er-Fehler.
Jede Hilfe wäre willkommen.
