hangvar
(Jonas Hangvar)
25 באפריל, 2016, 6:10am
1
Hi,
I’ve setup my Discourse instance and my Ghost on the same server in Docker containers, using nginx to route to the different containers. But when trying to show the Ghost welcome page it gets stuck on “Loading Discussion…”.
I’ve configured embedding for blog.hyzerflip.rip and my code looks like this:
I can’t find anything in the Discourse logs.
Is there anything in the browser JavaScript console?
hangvar
(Jonas Hangvar)
28 באפריל, 2016, 6:30am
3
Good idea! I get these two suspicious responses:
I meant errors not responses. As in, JavaScript errors.
hangvar
(Jonas Hangvar)
28 באפריל, 2016, 2:10pm
5
Please excuse my ignorance. Here is a new attempt with JavaScript errors:
Failed to load resource: the server responded with http://blog.hyzerflip.rip/welcome-to-ghost/<a%20href="http:/hyzerflip.rip/">http://hyzerflip.rip/</a>javascripts/embed.js/ a status of 404 (Not Found)
Refused to display ‘http://hyzerflip.rip/embed/comments?embed_url=http%3A%2F%2Fblog.hyzerflip.rip<%25%3D%20current_page.url%20%25> ’ in a frame because it set ‘X-Frame-Options’ to ‘SAMEORIGIN’.
Hello even as of date i too am getting the same error.
sam
(Sam Saffron)
19 ביוני, 2016, 11:42pm
7
is there anything in the /logs
Message (634 copies reported)
Job exception: redirection forbidden: http://blog.discuss.moe/thoughts-on-kabaneri-of-the-iron-fortress/ -> https://blog.discuss.moe/thoughts-on-kabaneri-of-the-iron-fortress/
Backtrace
/usr/local/lib/ruby/2.3.0/open-uri.rb:225:in `open_loop'
/usr/local/lib/ruby/2.3.0/open-uri.rb:151:in `open_uri'
/var/www/discourse/lib/freedom_patches/open_uri_redirections.rb:70:in `open_uri'
/usr/local/lib/ruby/2.3.0/open-uri.rb:717:in `open'
/usr/local/lib/ruby/2.3.0/open-uri.rb:35:in `open'
/var/www/discourse/app/models/topic_embed.rb:79:in `find_remote'
/var/www/discourse/app/models/topic_embed.rb:116:in `import_remote'
/var/www/discourse/lib/topic_retriever.rb:56:in `fetch_http'
/var/www/discourse/lib/topic_retriever.rb:43:in `perform_retrieve'
/var/www/discourse/lib/topic_retriever.rb:10:in `retrieve'
/var/www/discourse/app/jobs/regular/retrieve_topic.rb:16:in `execute'
/var/www/discourse/app/jobs/base.rb:154:in `block (2 levels) in perform'
Env
hostname animeforums-app
process_id [26401, 19253, 11990, 1694, 175, 23165, 887]
application_version [cdfe2b814453d24f4d7c98454aac1cdf0c2f61f3, efafdd252ef9df4aedfe2979e9509cfcecaced30, d374913547ad287385edbfee85a05e4f683dc3ab, 605a30254693ea59f42e6c241ee22febb61f7d2d, d7bc8ec752a220128932ef43314ffc237bd6c016, 96c07985b335b64e6fddaf8e9af2ed6feaf24a5d]
current_db default
current_hostname discuss.moe
job Jobs::RetrieveTopic
problem_db default
opts null
user_id [3, 1, 45, 44]
embed_url http://blog.discuss.moe/thoughts-on-kabaneri-of-the-iron-fortress/
referer [https://blog.discuss.moe/, https://blog.discuss.moe]
current_site_id default
The error i am getting as of now.
sam
(Sam Saffron)
21 ביוני, 2016, 12:34am
9
Why are you embedding a redirect as the URL for the source?
Thanks for pointing out. I had the domain set to http, even after I added a new certificate. Solved.
