discourse-fully 加上代理添加成主题,impore接口报422 unprocessable policy是什么原因,怎么可以解决
Hi there, could you send a screenshot of the error, and clarify further on the problem you’re facing? Thanks.
(For English readers, the error says “Error cloning git repository, access denied or repository not found”)
If you uninstall the theme and reinstall it, does it work?
还是会有这个问题,还有其他解决方案吗???
On-screen, are there any visible errors, or does it fail silently? Could you also share the URL which you are importing the theme from?
这个问题已经得到解决,谢谢你的回答~~
