Discourse Keybase Proof
Ok, so I should just redirect back to the new_proof_url endpoint, fair enough :slight_smile:
yeah. redirecting is perfect. it doesn’t have to redirect to new it could also go to the user’s profile page or settings page or something like that as long as the flash notice tells the user something actionable. whatever makes the most sense. i’m not really sure. no opinions.
the logged-in user is the discourse user that is making the proof
absolutely. yes. it looked like here we’re only checking if it’s the correct user on create and i’d argue we should also do it on new. there’s no sense in trying to save a proof that we know will fail.
The code I pushed is not the latest. I rewrote the create method, removing the check for the username param as it should not be necessary anymore (as the proof_valid? check will fail).
The new method is just a placeholder for Discourse routing logic, it will never be called and it needs to allow non-logged-in requests to allow the user to log in if they logged off previously :slight_smile:
EDIT: this is the new code I just pushed (still not very polished, I pushed it just to let you see it).
2 лайка
About setting up a test domain: it would be great :slight_smile:
3 лайка
I am having issues updating the proof custom field. The first time I put a JSON object in it, it works, but any attempt to change the value of the custom field fails. This is the code:
    def create
      kb_username = params.fetch('kb_username')
      sig_hash = params.fetch('sig_hash')
      proof = Proof.new(current_user.username, kb_username, sig_hash)
      unless proof.valid?
        raise Discourse::InvalidParameters, I18n.t('keybase_proofs.invalid_proof')
      proofs = current_user.custom_fields['keybase_proofs'] || {}
      # Override the signature because the old one might have been
      # revoked and not yet updated on our side.
      proofs[kb_username] = proof.signature
      current_user.custom_fields['keybase_proofs'] = proofs
      current_user.save
      render json: success_json
the first time this code is called, it adds the proofs to the custom field named "keybase_proofs". If I call it again, it doesn’t update the custom field.
Some more information: if I change the type of the custom field to a string, it works correctly.
1 лайк
Is that code up to date in GitHub?
I assume that
Is not returning a hash, so on the first time it works because you coalesce it to an empty Hash. But it fails on subsequent tries because it’s returning something else.
Adding a debugging break point there may help.
2 лайка
Unfortunately not. Since I am learning how everything works together, my code is almost always in a very sad shape, not really worth pushing. But the code that is in GitHub shows exactly the same issue (but I didn’t push the tests).
In the latest version of the code, which I have locally, I got rid of the JSON type and I am just using serialized JSON strings instead, and it is now working fine.
This is not the case. When I say that “it fails”, I mean “it fails to update” the field. So the first time the code runs, it saves the custom field correctly (I can also retrieve it, I use the data in the profile page and in the check proof endpoint). The second time I run the code (ie, if I add another Keybase identity to the same Discourse user), the custom field is not updated, it keeps only the first signature I added.
In case you’re curious and you want to debug the issue, I’ll create a branch with the original code and tests (that were failing) so you can investigate :slight_smile:
Unfortunately I don’t know how to do it for this codebase using VS Code :frowning: do you have any advice on an alternative editor? RubyMine?
Thanks!
You can add a byebug to any line in the controller, and when that line is hit the console where you started the webserver (the one you run bin/unicorn -x) will stop and allow you to inspect the variables.
9 лайков
The debugger confirms what I saw with previous testing: the JSON is stored the first time, and any attempt to change it later gets silently ignored. Anyway, for now I have fixed it by manually parsing/encoding the JSON string in the custom field.
Hello everyone! In particular @sam and @kb_xgess.
The plugin is in good enough shape now to get reviewed: GitHub - etamponi/discourse-keybase-proofs-plugin: Discourse Plugin for Keybase Proofs.
It should mostly work. There are a few things to fix before it is “shippable”:
  • The “new proof” UI needs some CSS love. It should also show an error if the logged in user is not the one for which the proof is requested.
  • The config endpoint /keybase-proofs/config needs a couple of SVG logos, but I don’t know where to get them from. Ideas? @kb_xgess, do they need to be SVG? Do you need both the black&white and the colored one?
  • redirect-after-login doesn’t work currently. @techAPJ is investigating, might be a bug in Discourse core or (more likely?) a bug somewhere in the plugin.
Some notes on code quality:
  • I didn’t write frontend tests. I think I’ve got the gist of how to write tests for components, but I didn’t want to spend more time figuring out how to mock requests and so on.
  • proof_controller.rb has a very ugly pic_url method, needed because I couldn’t make the call to the keybase API from the client because of CORS. I guess it can be moved to somewhere else or someone can figure out how to fetch the information from the client side.
  • I didn’t run any linter/formatter on the code. Should I?
  • The README might need some love :slight_smile:
7 лайков
Я бы с удовольствием протестировал это. Есть ли доступный тестовый экземпляр?
2 лайка
Какой URL конечной точки? Возможно, его можно запросить у разработчиков?
Насколько мне известно, это нужно разрешить для каждого экземпляра отдельно со стороны команды Keybase.
@kb_xgess, не могли бы вы добавить для нас meta.discourse.org?
2 лайка
Сейчас просматриваю часть вашего кода. :slight_smile: Отличный прогресс! Быстрый вопрос по поводу meta.discourse.org: там используется другая кодовая база? Можем ли мы развернуть ваш код там? Спрашиваю, потому что часть протокола взаимодействия — это запросы Keybase к Discourse для проверки размещённого доказательства. Если его нет, всё просто не сработает. Поэтому вам, возможно, будет проще итерировать на публичном сервере, который менее ориентирован на продакшн. Если это имеет смысл. Возможно, это будет staging-окружение или хостинг для разработки. Или, даже если у вас есть аккаунт в ngrok, мы можем создать статический URL, который всегда будет проксировать запросы на ваш локальный хост, и он будет активен только тогда, когда вам это нужно (полностью с вашей стороны). Если у вас есть необходимая гибкость на meta.discourse.org, я могу включить это для этого сайта, используя конфигурации из вашего кода и некоторые другие настройки по умолчанию.
Другой вопрос касается SVG. SVG идеально подходят, потому что нам на самом деле нужно несколько PNG-изображений разных размеров для мобильного приложения, десктопного приложения и веб-сайта, и, скорее всего, всем будет проще, если мы сможем генерировать их все из одних и тех же исходных данных.
5 лайков
Это разочаровывает. Так ли это обязательно, @kb_xgess? Я надеялся, что можно просто, скажем, предоставить Keybase ссылку на профиль на любом сервере Discourse с установленным плагином (или на любом сервере Discourse, если функционал будет включён в ядро), и тогда подтверждение будет работать на любом сервере Discourse.
В их сообщении об объявлении при запуске сервиса это было очень четко указано.
Если вы можете легко добавлять домены, пожалуйста, добавьте один для keybase-test.demo.discourse.org, который я скоро запущу для наших тестов.
4 лайка
О. Похоже, я не следил так внимательно, как думал. :crying_cat_face:
Подождите. Это не то, что я понял из первого сообщения:
А, но в статье Keybase ♥'s Mastodon, and how to get your site on Keybase говорится, что они не будут ссылаться на
Это имеет смысл, боюсь. :wink:
6 лайков
Да, в планах — создание всего необходимого инструментария, и я уверен, что @kb_xgess включит его для сообществ, где это имеет смысл. Это не означает, что он будет доступен для каждого «призрачного» города или экземпляра, требующего входа в систему.
4 лайка
Поддерживает ли плагин этот старомодный способ? Я не совсем уверен.
1 лайк
Нет, поддерживается новый способ, но для этого требуется включение в белый список Keybase.
Таким образом вы доказываете KeyBase, что владеете веб-сайтом. Я думал, что подобный метод может сработать. Я ошибался.
