Discourse-official-slack: no error message after failed post to slack
The discussion addresses a bug where the Slack plugin fails to log errors when Slack notifications fail, such as with an invalid webhook URL. supermathie reports that no error messages appear in the logs, even when testing notifications. david explains that this issue is resolved in the upcoming discourse-chat-integration plugin, which logs errors and displays them in the admin interface. supermathie also notes that the existing ‘Test Notification’ button is unreliable because it randomly selects a post that may not match the notification filters. david confirms that the new plugin fixes this by allowing users to select a specific topic for testing, eliminating the randomness.
While investigating a (probably) unrelated problem I noticed that the slack plugin does not post any kind of message to the error logs (https://site/logs) if the slack notification fails.
Tested by setting an invalid slack outbound webhook url on a site and posting a new topic as well as pressing ‘Test Notifications’.
This is one of the things I fixed with discourse-chat-integration, which hopefully will be replacing the slack plugin very soon - it writes errors to the site logs, and shows them in the admin interface next to the associated “channel” as well.
For example:
3 curtidas
Nice, can’t wait for this!
FWIW, I also discovered that the existing ‘Test Notification’ button is a gamble - it isn’t guaranteed to send out a notification. It only does if the post it randomly selects matches the filters.
3 curtidas
Yep, that’s another thing that’s fixed. discourse-chat-integration allows the user to select a specific topic to send, so there’s no chance of it trying to send a PM, and then failing :smiley:
3 curtidas
