Discourse Prometheus 404 指标用于 Grafana
Continuing the discussion from Discourse Prometheus:
Not sure what’s happening but this integration is not working anymore. I couldn’t get the dashboard in grafana to display anything… the /metrics does return something but anything beyond that does not really work
Many errors like the one below
Started GET "/metrics/api/v1/label/instance/values?limit=40000&start=1760980620&end=1760982480&match%5B%5D=discourse_page_views" for 16.63.57.20 at 2025-10-20 17:47:07 +0000
Started GET "/metrics/api/v1/label/job/values?limit=40000&start=1760980620&end=1760982480&match%5B%5D=discourse_page_views%7B%7D" for 16.63.57.20 at 2025-10-20 17:47:07 +0000
  Rendered layout layouts/no_ember.html.erb (Duration: 21.1ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 26.0ms | GC: 0.0ms)
Started POST "/metrics/api/v1/query_range" for 16.63.57.20 at 2025-10-20 17:47:07 +0000
  Rendered layout layouts/no_ember.html.erb (Duration: 19.8ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 28.2ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 34.6ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 44.4ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 41.7ms | GC: 0.0ms)
Started POST "/metrics/api/v1/query_range" for 16.63.57.20 at 2025-10-20 17:47:08 +0000
  Rendered layout layouts/no_ember.html.erb (Duration: 23.6ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 24.9ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 19.9ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 21.6ms | GC: 0.0ms)
Started GET "/metrics/api/v1/label/job/values?limit=40000&start=1760980620&end=1760982480&match%5B%5D=discourse_page_views%7B%7D" for 16.63.57.20 at 2025-10-20 17:47:37 +0000
Started GET "/metrics/api/v1/label/instance/values?limit=40000&start=1760980620&end=1760982480&match%5B%5D=discourse_page_views" for 16.63.57.20 at 2025-10-20 17:47:37 +0000
  Rendered layout layouts/no_ember.html.erb (Duration: 19.5ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 20.9ms | GC: 0.0ms)
Started POST "/metrics/api/v1/query_range" for 16.63.57.20 at 2025-10-20 17:47:37 +0000
  Rendered layout layouts/no_ember.html.erb (Duration: 22.4ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 22.0ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 40.0ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 37.0ms | GC: 0.0ms)
  Rendered layout layouts/no_ember.html.erb (Duration: 24.8ms | GC: 1.6ms)
I have managed to make this work. My problems were:
  1. My instance redirects to `https`
  2. The default grafana configuration for `alloy` was trying to reach localhost:80 (if you don’t know, `alloy` is a prometheus-like server that grafana spins and reads `/metrics` to expose them to grafana)
this is what my config looks like in case it helps anyone
... removed the part that's auto generated when installing alloy ...
discovery.relabel "metrics_integrations_integrations_discourse" {
	targets = [{
		__address__ = "your.domain.com", # <--- THIS IS A CHANGE I DID
		__scheme__  = "https", # <--- THIS IS A CHANGE I DID
	rule {
		target_label = "instance"
		replacement  = constants.hostname
prometheus.scrape "metrics_integrations_integrations_discourse" {
	targets    = discovery.relabel.metrics_integrations_integrations_discourse.output
	forward_to = [prometheus.relabel.metrics_integrations_integrations_discourse.receiver]
	job_name   = "integrations/discourse"
	tls_config {
		insecure_skip_verify = true # <--- THIS IS A CHANGE I DID
prometheus.relabel "metrics_integrations_integrations_discourse" {
	forward_to = [prometheus.remote_write.metrics_service.receiver]
	rule {
		source_labels = ["__name__"]
		regex         = "up|discourse_active_app_reqs|discourse_http_duration_seconds|discourse_http_requests|discourse_page_views|discourse_queued_app_reqs|discourse_rss|discourse_scheduled_job_count|discourse_scheduled_job_duration_seconds|discourse_sidekiq_job_count|discourse_sidekiq_job_duration_seconds|discourse_sidekiq_jobs_enqueued|discourse_v8_used_heap_size"
		action        = "keep"
with this grafana started getting data…
Don’t forget to set DISCOURSE_PROMETHEUS_TRUSTED_IP_ALLOWLIST_REGEX
I searched for grafana’s IPs and added them all as a long line, there may be a better or smarter way but I couldn’t find it lol
here’s an example of adding multiple ips
DISCOURSE_PROMETHEUS_TRUSTED_IP_ALLOWLIST_REGEX: "^(localhost|127\\.0\\.0\\.1|::1)$
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
