Discourse: If S3 is enabled, is it recommended to configure in the yml or the admin panel?
Hi, for Discourse, if enabling S3, is it recommended to configure it in the YML file or via the admin UI (/admin/site_settings/category/files)?
We recommend the YML file if you’re self-hosting, Configure an S3 compatible object storage provider for uploads
If you’re using discourse.org hosting we handle upload storage, so you don’t have access to these settings.
