Discourse-setup: regel 260: *0: syntaxisfout: operand verwacht (fout token is "*0")
first installation and got this error:
discourse-setup: line 260: *0: syntax error: operand expected (error token is "*0") Hostname for your Discourse? [discourse.example.com]:
Any suggestion what went wrong?
Hi, welcome back!
Can you detail what OS you are trying to install Discourse with?
Hi There! This is Ubuntu 20.04.6 LTS
Linux ubuntu 5.4.0-1082-raspi aarch64 aarch64 aarch64 GNU/Linux
I think I’d suggest starting with a git pull. And then if the script still does this, perhaps instead try
bash -vx ./discourse-setup
and we might be able to see what’s happening. (I don’t see how line 260 could cause this trouble)
the line in 260:
avail_cores=$((`awk '/cpu cores/ {print $4;exit}' /proc/cpuinfo`*`sort /proc/cpuinfo | uniq | grep -c "physical id"`))
output of bash -x:
scale_ram_and_cpu
+ scale_ram_and_cpu
+ local changelog=/tmp/changelog.11937
+ avail_gb=0
+ avail_cores=0
++ check_OS
+++ uname -s
++ echo Linux
+ os_type=Linux
+ '[' Linux == Darwin ']'
++ check_linux_memory
+++ free -m --si
+++ awk ' /Mem:/ {print $2}'
++ mem=3975
++ '[' 3975 -ge 990 -a 3975 -lt 1000 ']'
+++ free -g --si
+++ awk ' /Mem:/  {print $2} '
++ echo 3
+ avail_gb=3
++ awk '/cpu cores/ {print $4;exit}' /proc/cpuinfo
++ sort /proc/cpuinfo
++ uniq
++ grep -c 'physical id'
./discourse-setup: line 260: *0: syntax error: operand expected (error token is "*0")
cat /proc/cpuinfo:
root@ubuntu:/var/discourse# cat /proc/cpuinfo
processor	: 0
BogoMIPS	: 108.00
Features	: fp asimd evtstrm crc32 cpuid
CPU implementer	: 0x41
CPU architecture: 8
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 1
BogoMIPS	: 108.00
CPU architecture: 8
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 2
BogoMIPS	: 108.00
CPU architecture: 8
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 3
BogoMIPS	: 108.00
CPU architecture: 8
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
Hardware	: BCM2835
Revision	: c03112
Serial		: 10000000d0894f90
Model		: Raspberry Pi 4 Model B Rev 1.2
There are several ways to go here, I think. Perhaps I’d go for
avail_cores=$((`lscpu --parse=core | awk 'NF==1' | sort -u | wc -l`))
(we’re trying to calculate the total number of presently-online physical cores - not logical cores, cpus, sockets, or processors)
Would that work in your case?
yes - it gives back 4
so maybe better to use lscpu instead of parsing /proc/cpuinfo
Great - I’ve submitted a PR
