I am in trouble to set up discourse now.
Anyone have a good idea?
I’m following this INSTALL-cloud.md
./discourse-setup
./discourse-setup: line 93: free: command not found
./discourse-setup: line 116: [: : integer expression expected
./discourse-setup: line 125: [: : integer expression expected
The configuration file containers/app.yml already exists!
. . . reconfiguring . . .
Saving old file as app.yml.2018-06-24-170535.bak
Stopping existing container in 5 seconds or Control-C to cancel.
stat: /var/lib/docker: stat: No such file or directory
./launcher: line 204: /1024**3 < 5: syntax error: operand expected (error token is "/1024**3 < 5")
app was not started !
Found GB of memory and 4 physical CPU cores
./discourse-setup: line 197: [: : integer expression expected
./discourse-setup: line 201: [: : integer expression expected
./discourse-setup: line 205: 256 * : syntax error: operand expected (error token is " ")
Hostname : xxx.websitename.com
Email : admin@websitename.com,admin2@websitename.com
SMTP address : smtp.mailgun.org
SMTP port : 587
SMTP username : postmaster@xxx.websitename.com
SMTP password : ---------------------
ENTER to continue, 'n' to try again, Ctrl+C to exit:
DISCOURSE_SMTP_PORT change failed.
DISCOURSE_SMTP_USER_NAME change failed.
DISCOURSE_SMTP_PASSWORD change failed.
web.ssl.template.yml NOT DISABLED--Are you using a non-standard template?
Unfortunately, there was an error changing
-d This may happen if you have made unexpected changes.
