Discourse stopped working all of a sudden
Deenius reported that their Discourse instance suddenly became inaccessible after editing posts, despite no recent configuration changes except adding a DNS TXT record for Google Search Console verification. Initial attempts to rebuild the app failed with network-related errors like ESOCKETTIMEDOUT and info There appears to be trouble with your network connection, prompting itsbhanusharma to suspect transient connectivity issues. Rebuilding repeatedly failed until Deenius updated Docker and eventually succeeded on the tenth try — yet the site remained unreachable. Other services like WordPress, Nginx Proxy Manager, and Portainer continued working normally on the same server, ruling out general server failure. After further troubleshooting, Deenius resolved the issue by adding an explicit A record for forum.domain.com in DNS, even though wildcard *.domain.com had previously worked. The root cause remains unclear, but the fix restored access. itsbhanusharma had earlier requested a full discourse-doctor log and redacted app.yml for deeper diagnostics, which Deenius provided, though access to the forum itself was down during troubleshooting. The issue appears to have been DNS-related, possibly triggered or exacerbated by the TXT record addition, though no definitive explanation was found.
Hello,
My discourse stopped working all of a sudden.
I was editing some posts this morning, but about two hours ago, the discourse disappeared. In other words, it’s not accessible.
Yesterday, I added a TXT record to DNS to verify what Google Search Console is asking for. This should hopefully have no effect. I didn’t change anything else!
Nor did I make any changes to my NGINX Proxy Manager.
I tried to rebuild the application but without success. The log is at the end of this text.
Can you please advise me on how to fix this? I don’t know what to do. Thank you.
root@vmi1695712:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20240602-0023: Pulling from discourse/base
Digest: sha256:5e0c30da851a00e824a58b033d59b8f3dd840b513a7694a7a5d0674285c0ee3c
Status: Image is up to date for discourse/base:2.0.20240602-0023
docker.io/discourse/base:2.0.20240602-0023
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-07-04T13:38:50.541714 #1]  INFO -- : Reading from stdin
I, [2024-07-04T13:38:50.560922 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-07-04T13:38:50.569920 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-07-04T13:38:50.639464 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-07-04T13:38:50.647493 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-07-04T13:38:50.657009 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-07-04T13:38:50.662175 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.663544 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.663970 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.664802 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.665410 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.665995 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.666444 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.667277 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.667726 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T13:38:50.669744 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-07-04T13:38:50.670470 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-07-04T13:38:50.734826 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-07-04T13:38:50.735770 #1]  INFO -- : > [ -f /root/install_postgres ] && /root/install_postgres && rm -f /root/install_postgres
I, [2024-07-04T13:38:54.865947 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-07-04T13:38:54.866404 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-07-04T13:38:55.047164 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2024-07-04T13:38:55.060731 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-07-04T13:38:55.147051 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-07-04T13:38:55.148314 #1]  INFO -- : > sleep 5
2024-07-04 13:38:55.452 UTC [35] LOG:  starting PostgreSQL 13.15 (Debian 13.15-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-07-04 13:38:55.453 UTC [35] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-07-04 13:38:55.453 UTC [35] LOG:  listening on IPv6 address "::", port 5432
2024-07-04 13:38:55.462 UTC [35] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-07-04 13:38:55.554 UTC [44] LOG:  database system was shut down at 2024-07-04 13:37:27 UTC
2024-07-04 13:38:55.649 UTC [35] LOG:  database system is ready to accept connections
I, [2024-07-04T13:39:00.161334 #1]  INFO -- :
I, [2024-07-04T13:39:00.162068 #1]  INFO -- : > /usr/local/bin/create_db
2024-07-04 13:39:00.363 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2024-07-04 13:39:00.363 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
2024-07-04 13:39:00.500 UTC [57] postgres@discourse ERROR:  role "discourse" already exists
2024-07-04 13:39:00.500 UTC [57] postgres@discourse STATEMENT:  create user discourse;
NOTICE:  extension "hstore" already exists, skipping
NOTICE:  extension "pg_trgm" already exists, skipping
NOTICE:  extension "vector" already exists, skipping
I, [2024-07-04T13:39:02.697895 #1]  INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
UPDATE 0
I, [2024-07-04T13:39:02.699742 #1]  INFO -- : > echo postgres installed!
I, [2024-07-04T13:39:02.708219 #1]  INFO -- : postgres installed!
I, [2024-07-04T13:39:02.729734 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-07-04T13:39:02.797663 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-07-04T13:39:02.825472 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-07-04T13:39:02.873773 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-07-04T13:39:02.875722 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-07-04T13:39:02.876708 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-07-04T13:39:02.889171 #1]  INFO -- :
I, [2024-07-04T13:39:02.890520 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-07-04T13:39:02.902744 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-07-04T13:39:02.905419 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-07-04T13:39:02.905957 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-07-04T13:39:02.906493 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-07-04T13:39:02.909850 #1]  INFO -- : > echo redis installed
I, [2024-07-04T13:39:02.974306 #1]  INFO -- : redis installed
I, [2024-07-04T13:39:02.975084 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-07-04T13:39:03.004950 #1]  INFO -- : logfile ""
I, [2024-07-04T13:39:03.005298 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-07-04T13:39:03.010638 #1]  INFO -- : > sleep 10
97:C 04 Jul 2024 13:39:03.110 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
97:C 04 Jul 2024 13:39:03.110 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=97, just started
97:C 04 Jul 2024 13:39:03.110 # Configuration loaded
97:M 04 Jul 2024 13:39:03.111 * monotonic clock: POSIX clock_gettime
97:M 04 Jul 2024 13:39:03.111 * Running mode=standalone, port=6379.
97:M 04 Jul 2024 13:39:03.112 # Server initialized
97:M 04 Jul 2024 13:39:03.112 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
97:M 04 Jul 2024 13:39:03.114 * Loading RDB produced by version 7.0.7
97:M 04 Jul 2024 13:39:03.114 * RDB age 99 seconds
97:M 04 Jul 2024 13:39:03.114 * RDB memory usage when created 19.56 Mb
97:M 04 Jul 2024 13:39:03.278 * Done loading RDB, keys loaded: 918, keys expired: 7.
97:M 04 Jul 2024 13:39:03.279 * DB loaded from disk: 0.165 seconds
97:M 04 Jul 2024 13:39:03.279 * Ready to accept connections
I, [2024-07-04T13:39:13.020261 #1]  INFO -- :
I, [2024-07-04T13:39:13.021592 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-07-04T13:39:13.038723 #1]  INFO -- : thpoff is installed!
I, [2024-07-04T13:39:13.039801 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-07-04T13:39:13.328795 #1]  INFO -- :
I, [2024-07-04T13:39:13.329441 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-07-04T13:39:13.723818 #1]  INFO -- :
I, [2024-07-04T13:39:13.724044 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-07-04T13:39:14.221328 #1]  INFO -- :
I, [2024-07-04T13:39:14.221855 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-07-04T13:39:14.226952 #1]  INFO -- :
I, [2024-07-04T13:39:14.232653 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-07-04T13:39:14.313293 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-07-04T13:39:14.325373 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-07-04T13:39:14.341701 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-07-04T13:39:14.429720 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-07-04T13:39:14.442944 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-07-04T13:39:14.443716 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
  rm /root/install_postgres
fi
sv start postgres || exit 1
 in /etc/service/unicorn/run
I, [2024-07-04T13:39:14.511433 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
Updating files: 100% (34508/34508), done.
I, [2024-07-04T13:39:31.789206 #1]  INFO -- : HEAD is now at 62b1b69e8 UX: constrain width of chat transcripts in posts (#27288)
I, [2024-07-04T13:39:31.792178 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-07-04T13:39:32.598288 #1]  INFO -- :
I, [2024-07-04T13:39:32.598634 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/add_filter_webhook_events_by_status
 - [deleted]             (none)     -> origin/add_lifecycle_rule_for_inventories
 - [deleted]             (none)     -> origin/application-route-actions
 - [deleted]             (none)     -> origin/avoid_unformatted_logs
 - [deleted]             (none)     -> origin/categories-modal-fix
 - [deleted]             (none)     -> origin/decorator-transforms-take-2
 - [deleted]             (none)     -> origin/dependabot/bundler/rails_failover-2.1.0
 - [deleted]             (none)     -> origin/dependabot/bundler/sqlite3-2.0.2
 - [deleted]             (none)     -> origin/dev/ember-58-upgrade-playground
 - [deleted]             (none)     -> origin/dev/rfc-value-modifier-plugin-api
 - [deleted]             (none)     -> origin/dev/standalone-home-logo-contents-component
 - [deleted]             (none)     -> origin/discourse-route-actions
 - [deleted]             (none)     -> origin/discourse-url-native-class
 - [deleted]             (none)     -> origin/feature/user-fields-required-for-existing-users-2
 - [deleted]             (none)     -> origin/fix-bbcode-parser
 - [deleted]             (none)     -> origin/fix-group-chat-member-count
 - [deleted]             (none)     -> origin/ghost-button
 - [deleted]             (none)     -> origin/issue/bulk-action-pm-fixes
 - [deleted]             (none)     -> origin/loic-update-to-rails-7.1
 - [deleted]             (none)     -> origin/migrations-tooling/converter
 - [deleted]             (none)     -> origin/permalinks
 - [deleted]             (none)     -> origin/remove-disable-sidebar
 - [deleted]             (none)     -> origin/route-native-class
 - [deleted]             (none)     -> origin/search-result-consistency
 - [deleted]             (none)     -> origin/support_alternate_bucket_s3_inventory
 - [deleted]             (none)     -> origin/update-official-plugin-list
 - [deleted]             (none)     -> origin/user-posts-stream-native-class
 - [deleted]             (none)     -> origin/ux-account-disclaimer
 - [deleted]             (none)     -> origin/with-ancestor-ids
   62b1b69e8..0d608ceff  main                    -> origin/main
 * [new branch]          0-a-fix-high            -> origin/0-a-fix-high
 * [new branch]          add_mechanism_to_redeliver_all_webhook_events -> origin/add_mechanism_to_redeliver_all_webhook_events
 * [new branch]          add_mechanism_to_redeliver_all_webhook_events_wip -> origin/add_mechanism_to_redeliver_all_webhook_events_wip
 * [new branch]          better_logs             -> origin/better_logs
 * [new branch]          chat-empty-state        -> origin/chat-empty-state
 * [new branch]          chat-mobile-menu        -> origin/chat-mobile-menu
 + 098e99e83...bfdeae4f4 coco/generic-importer   -> origin/coco/generic-importer  (forced update)
 * [new branch]          dependabot/bundler/libv8-node-21.7.2.0 -> origin/dependabot/bundler/libv8-node-21.7.2.0
 * [new branch]          dependabot/bundler/oauth2-2.0.9 -> origin/dependabot/bundler/oauth2-2.0.9
 * [new branch]          dependabot/bundler/omniauth-2.1.2 -> origin/dependabot/bundler/omniauth-2.1.2
 * [new branch]          dependabot/bundler/omniauth-google-oauth2-1.1.2 -> origin/dependabot/bundler/omniauth-google-oauth2-1.1.2
 * [new branch]          detect-default-readonly -> origin/detect-default-readonly
 * [new branch]          dev-can-ignore-users    -> origin/dev-can-ignore-users
 * [new branch]          dev/add-behavior-transformers -> origin/dev/add-behavior-transformers
 * [new branch]          dev/ember-source-5.9.0-upgrade -> origin/dev/ember-source-5.9.0-upgrade
 * [new branch]          dev/untangle-admin-sidebar -> origin/dev/untangle-admin-sidebar
 * [new branch]          feature/absolute-number-in-poll -> origin/feature/absolute-number-in-poll
 * [new branch]          feature/private-github-onebox -> origin/feature/private-github-onebox
 * [new branch]          fix-ensure-post-and-topic-user-id-is-always-set -> origin/fix-ensure-post-and-topic-user-id-is-always-set
 * [new branch]          fix-password-reset-security-key -> origin/fix-password-reset-security-key
 * [new branch]          fix-unread-notifications-take-2 -> origin/fix-unread-notifications-take-2
 * [new branch]          fix/table-break-line    -> origin/fix/table-break-line
   b3d6801e8..2902da16e  formtoolkit             -> origin/formtoolkit
 * [new branch]          grant-admin-fetch-user  -> origin/grant-admin-fetch-user
 * [new branch]          issue/do-not-enforce-2fa-on-social-logins -> origin/issue/do-not-enforce-2fa-on-social-logins
 * [new branch]          issue/fix-user-field-enum-migrate -> origin/issue/fix-user-field-enum-migrate
 * [new branch]          issue/prevent-decimal-comma-integer-input-site-setting -> origin/issue/prevent-decimal-comma-integer-input-site-setting
 * [new branch]          jjaffeux-otp-validation -> origin/jjaffeux-otp-validation
 * [new branch]          loic-use-messageformat-gem -> origin/loic-use-messageformat-gem
 * [new branch]          mt/converter            -> origin/mt/converter
 * [new branch]          mt/uploads-command      -> origin/mt/uploads-command
 * [new branch]          prevent-header-cls      -> origin/prevent-header-cls
 * [new branch]          rails_7_1_upgrade       -> origin/rails_7_1_upgrade
 * [new branch]          show-primary-user-group-options-to-members -> origin/show-primary-user-group-options-to-members
   5558028f8..473248381  stable                  -> origin/stable
 * [new branch]          tag-span                -> origin/tag-span
   62b1b69e8..0d608ceff  tests-passed            -> origin/tests-passed
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.2.3                  -> v3.2.3
 * [new tag]             v3.3.0.beta3            -> v3.3.0.beta3
I, [2024-07-04T13:39:34.299514 #1]  INFO -- :
I, [2024-07-04T13:39:34.299788 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-07-04T13:39:41.631661 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-07-04T13:39:41.632287 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-07-04T13:39:41.649903 #1]  INFO -- :
I, [2024-07-04T13:39:41.650148 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-07-04T13:39:41.721358 #1]  INFO -- :
I, [2024-07-04T13:39:41.722593 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-07-04T13:39:41.727871 #1]  INFO -- :
I, [2024-07-04T13:39:41.729003 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-07-04T13:39:41.735635 #1]  INFO -- :
I, [2024-07-04T13:39:41.736747 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-07-04T13:39:41.742509 #1]  INFO -- :
I, [2024-07-04T13:39:41.743294 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-07-04T13:39:41.749797 #1]  INFO -- :
I, [2024-07-04T13:39:41.750489 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-07-04T13:39:41.821571 #1]  INFO -- :
I, [2024-07-04T13:39:41.822485 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-07-04T13:39:41.832200 #1]  INFO -- :
I, [2024-07-04T13:39:41.832830 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-07-04T13:39:41.840532 #1]  INFO -- :
I, [2024-07-04T13:39:41.841216 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-07-04T13:39:41.851218 #1]  INFO -- :
I, [2024-07-04T13:39:41.851816 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-07-04T13:39:41.925157 #1]  INFO -- :
I, [2024-07-04T13:39:41.925801 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-07-04T13:39:41.935066 #1]  INFO -- :
I, [2024-07-04T13:39:41.935779 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-07-04T13:39:41.943863 #1]  INFO -- :
I, [2024-07-04T13:39:41.944656 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-07-04T13:39:42.227885 #1]  INFO -- :
I, [2024-07-04T13:39:42.228719 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-07-04T13:39:42.231616 #1]  INFO -- :
I, [2024-07-04T13:39:42.232299 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-07-04T13:39:42.233701 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-07-04T13:39:44.732799 #1]  INFO -- :
I, [2024-07-04T13:39:44.734253 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-07-04T13:39:44.744794 #1]  INFO -- :
I, [2024-07-04T13:39:44.745634 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-07-04T13:39:44.830767 #1]  INFO -- :
I, [2024-07-04T13:39:44.831520 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-07-04T13:39:44.834670 #1]  INFO -- :
I, [2024-07-04T13:39:44.838515 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-07-04T13:39:44.840309 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-07-04T13:39:44.841050 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-07-04T13:39:44.841683 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-07-04T13:39:44.842894 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-07-04T13:39:44.931340 #1]  INFO -- : > echo "done configuring web"
I, [2024-07-04T13:39:44.935430 #1]  INFO -- : done configuring web
I, [2024-07-04T13:39:44.936120 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-07-04T13:39:45.835727 #1]  INFO -- :
I, [2024-07-04T13:39:45.836034 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-07-04T13:40:03.434005 #1]  INFO -- :
I, [2024-07-04T13:40:03.434989 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
  rm -rf app/assets/javascripts/node_modules
fi
I, [2024-07-04T13:40:03.442966 #1]  INFO -- :
I, [2024-07-04T13:40:03.443147 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
error Error: https://registry.yarnpkg.com/date-fns/-/date-fns-2.30.0.tgz: ESOCKETTIMEDOUT
    at ClientRequest.<anonymous> (/usr/share/yarn/lib/cli.js:142037:19)
    at Object.onceWrapper (node:events:631:28)
    at ClientRequest.emit (node:events:517:28)
    at TLSSocket.emitRequestTimeout (node:_http_client:847:9)
    at TLSSocket.emit (node:events:529:35)
    at Socket._onTimeout (node:net:598:8)
    at listOnTimeout (node:internal/timers:569:17)
    at process.processTimers (node:internal/timers:512:7)
I, [2024-07-04T13:44:53.619485 #1]  INFO -- : yarn install v1.22.22
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
info There appears to be trouble with your network connection. Retrying...
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
I, [2024-07-04T13:44:53.623961 #1]  INFO -- : Terminating async processes
I, [2024-07-04T13:44:53.624457 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 35
I, [2024-07-04T13:44:53.624901 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 97
2024-07-04 13:44:53.625 UTC [35] LOG:  received fast shutdown request
97:signal-handler (1720100693) Received SIGTERM scheduling shutdown...
2024-07-04 13:44:53.632 UTC [35] LOG:  aborting any active transactions
2024-07-04 13:44:53.642 UTC [35] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
97:M 04 Jul 2024 13:44:53.644 # User requested shutdown...
97:M 04 Jul 2024 13:44:53.644 * Saving the final RDB snapshot before exiting.
2024-07-04 13:44:53.650 UTC [45] LOG:  shutting down
2024-07-04 13:44:53.747 UTC [35] LOG:  database system is shut down
97:M 04 Jul 2024 13:44:53.932 * DB saved on disk
97:M 04 Jul 2024 13:44:53.932 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean' failed with return #<Process::Status: pid 268 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ \"$version\" != \"tests-passed\" ]; then\n  rm -rf app/assets/javascripts/node_modules\nfi", "su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'"]}
0ad323769e87ce77787965163c1889999c044d6dce2cb925cf43f92475148a14
root@vmi1695712:/var/discourse# ^C
and
suggest that your VM might be experiencing some connectivity issues. It could be transient. What happens if you run ./launcher rebuild app again ?
Rebuild has failed again. Same errors.
It’s weird because I’m running WordPress, Nginx proxy manager, and Portainer on the same server, and everything works.
It’s not weird because none of those services have anything to do with discourse.
You’ll need to provide a full log of failed build and more info about your setup to get any further help here.
Ok, no problem.
What log do you mean? How do I get it?
What other information do you need?
BTW, thank you for your help. I’m really lost right now.
Use ./discourse-doctor it’ll generate a file that you can share.
Second, if you could share a redacted app.yml then me or someone here might be able to see if there are some obvious issues like incompatible plugins etc.
Discourse doctor generates log. However, I am unable to share it via URL link.
My browser says this: The IP address of the forum.**********.com server was not found.
I’ll post it here.
I don’t know if this has any effect, but before discourse stopped working, a theme update was available. However, I haven’t done the update yet.
DISCOURSE DOCTOR Thu Jul 4 11:11:09 AM CDT 2024
OS: Linux vmi1695712.contaboserver.net 5.15.0-107-generic #117-Ubuntu SMP Fri Apr 26 12:26:49 UTC 2024 x86_64 x86_64 x86_64 GNU/Lin                          ux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=*********************
SMTP_ADDRESS=email-smtp.us-east-1.amazonaws.com
DEVELOPER_EMAILS=**************,****************
SMTP_PASSWORD=******************************************
SMTP_PORT=587
SMTP_USER_NAME=*************************************
LETSENCRYPT_ACCOUNT_EMAIL=me@example.com
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 25.0.4, build 1a576c5
DOCKER PROCESSES (docker ps -a)
CONTAINER ID   IMAGE                               COMMAND                  CREATED        STATUS                   PORTS        NAMES
ce55082edacf   local_discourse/app                 "/sbin/boot"             4 weeks ago    Exited (5) 3 hours ago        app
2623c7a72364   ghcr.io/goauthentik/server:2024.2   "dumb-init -- ak ser…"   3 months ago   Up 3 weeks (healthy)        authentik
c9aaf56f9eeb   jc21/nginx-proxy-manager:latest     "/init"                  3 months ago   Up 3 weeks               0.0.0.0:80->80/                          tcp, 0.0.0.0:443->443/tcp, 81/tcp   nginx_proxy_manager
e6d5c52fe8de   ghcr.io/goauthentik/server:2024.2   "dumb-init -- ak wor…"   3 months ago   Up 3 weeks (healthy)        authentik-worker-1
8676ee45a21d   postgres:12-alpine                  "docker-entrypoint.s…"   3 months ago   Up 3 weeks (healthy)     5432/tcp        authentik-postgresql-1
13bb9ab5f88c   redis:alpine                        "docker-entrypoint.s…"   3 months ago   Up 3 weeks (healthy)     6379/tcp        authentik-redis-1
174735dcc208   portainer/portainer-ce:latest       "/portainer"             3 months ago   Up 3 weeks        portainer
694372a6e79d   tailscale/tailscale:latest          "/usr/local/bin/cont…"   3 months ago   Up 3 weeks        portainer-tailscale-portainer-1
13de0af406c8   wordpress:latest                    "docker-entrypoint.s…"   3 months ago   Up 3 weeks               80/tcp        wordpress
ad068e38c59c   mysql:5.7                           "docker-entrypoint.s…"   3 months ago   Up 3 weeks               3306/tcp, 33060                          /tcp                                wordpress-db-1
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
==================== REBUILD LOG ====================
Fetching origin
app
I, [2024-07-04T16:11:39.322139 #1]  INFO -- : Reading from stdin
I, [2024-07-04T16:11:39.395213 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-07-04T16:11:39.399741 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-07-04T16:11:39.408014 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-07-04T16:11:39.415883 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-07-04T16:11:39.422053 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-07-04T16:11:39.422558 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shar                          ed/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.424073 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgre                          sql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.425303 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous                          _commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.425764 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /                          etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.426249 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/                          main/postgresql.conf
I, [2024-07-04T16:11:39.486651 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config =                           '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.487230 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoin                          t_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.487777 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_colle                          ctor in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.488319 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement =                           $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-07-04T16:11:39.488982 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgr                          es  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-07-04T16:11:39.489334 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/pos                          tgresql/13/main/pg_hba.conf
I, [2024-07-04T16:11:39.489655 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/pos                          tgresql/13/main/pg_hba.conf
I, [2024-07-04T16:11:39.489969 #1]  INFO -- : > [ -f /root/install_postgres ] && /root/install_postgres && rm -f /root/install_post                          gres
I, [2024-07-04T16:11:43.504790 #1]  INFO -- : Generating locales (this might take a while)...
I, [2024-07-04T16:11:43.505416 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U                           postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-07-04T16:11:43.600978 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2024-07-04T16:11:43.618510 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-07-04T16:11:43.704451 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-07-04T16:11:43.705704 #1]  INFO -- : > sleep 5
2024-07-04 16:11:43.726 UTC [36] LOG:  starting PostgreSQL 13.15 (Debian 13.15-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc                           (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-07-04 16:11:43.727 UTC [36] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-07-04 16:11:43.727 UTC [36] LOG:  listening on IPv6 address "::", port 5432
2024-07-04 16:11:43.799 UTC [36] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-07-04 16:11:43.806 UTC [45] LOG:  database system was shut down at 2024-07-04 16:09:46 UTC
2024-07-04 16:11:43.817 UTC [36] LOG:  database system is ready to accept connections
I, [2024-07-04T16:11:48.712694 #1]  INFO -- :
I, [2024-07-04T16:11:48.713998 #1]  INFO -- : > /usr/local/bin/create_db
2024-07-04 16:11:48.839 UTC [55] postgres@postgres ERROR:  database "discourse" already exists
2024-07-04 16:11:48.839 UTC [55] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
2024-07-04 16:11:48.966 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2024-07-04 16:11:48.966 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2024-07-04T16:11:50.853046 #1]  INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
UPDATE 0
I, [2024-07-04T16:11:50.853484 #1]  INFO -- : > echo postgres installed!
I, [2024-07-04T16:11:50.858311 #1]  INFO -- : postgres installed!
I, [2024-07-04T16:11:50.924492 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-07-04T16:11:50.934768 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-07-04T16:11:50.944045 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-07-04T16:11:50.945335 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-07-04T16:11:50.946689 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-07-04T16:11:50.947567 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-07-04T16:11:50.953926 #1]  INFO -- :
I, [2024-07-04T16:11:50.954947 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-07-04T16:11:50.955756 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-07-04T16:11:50.957367 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-07-04T16:11:50.958630 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-07-04T16:11:50.959769 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-07-04T16:11:50.960808 #1]  INFO -- : > echo redis installed
I, [2024-07-04T16:11:51.020508 #1]  INFO -- : redis installed
I, [2024-07-04T16:11:51.020879 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-07-04T16:11:51.027651 #1]  INFO -- : logfile ""
I, [2024-07-04T16:11:51.028264 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-07-04T16:11:51.030228 #1]  INFO -- : > sleep 10
98:C 04 Jul 2024 16:11:51.042 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
98:C 04 Jul 2024 16:11:51.042 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=98, just started
98:C 04 Jul 2024 16:11:51.042 # Configuration loaded
98:M 04 Jul 2024 16:11:51.043 * monotonic clock: POSIX clock_gettime
98:M 04 Jul 2024 16:11:51.044 * Running mode=standalone, port=6379.
98:M 04 Jul 2024 16:11:51.044 # Server initialized
98:M 04 Jul 2024 16:11:51.044 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail un                          der low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemal                          loc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command '                          sysctl vm.overcommit_memory=1' for this to take effect.
98:M 04 Jul 2024 16:11:51.045 * Loading RDB produced by version 7.0.7
98:M 04 Jul 2024 16:11:51.045 * RDB age 125 seconds
98:M 04 Jul 2024 16:11:51.045 * RDB memory usage when created 14.81 Mb
98:M 04 Jul 2024 16:11:51.150 * Done loading RDB, keys loaded: 840, keys expired: 0.
98:M 04 Jul 2024 16:11:51.150 * DB loaded from disk: 0.106 seconds
98:M 04 Jul 2024 16:11:51.151 * Ready to accept connections
I, [2024-07-04T16:12:01.046784 #1]  INFO -- :
I, [2024-07-04T16:12:01.047553 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-07-04T16:12:01.051993 #1]  INFO -- : thpoff is installed!
I, [2024-07-04T16:12:01.052660 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; put                          s "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-07-04T16:12:01.191284 #1]  INFO -- :
I, [2024-07-04T16:12:01.191894 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; pu                          ts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-07-04T16:12:01.354031 #1]  INFO -- :
I, [2024-07-04T16:12:01.354639 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Ab                          orting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-07-04T16:12:01.574116 #1]  INFO -- :
I, [2024-07-04T16:12:01.574514 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-07-04T16:12:01.578680 #1]  INFO -- :
I, [2024-07-04T16:12:01.654026 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-07-04T16:12:01.663931 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-07-04T16:12:01.671163 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-07-04T16:12:01.751159 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-07-04T16:12:01.761258 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-07-04T16:12:01.768764 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-07-04T16:12:01.769267 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
fi
I, [2024-07-04T16:12:01.770932 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
I, [2024-07-04T16:12:18.326043 #1]  INFO -- : HEAD is now at 62b1b69e8 UX: constrain width of chat transcripts in posts (#27288)
I, [2024-07-04T16:12:18.327297 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-07-04T16:12:19.106550 #1]  INFO -- :
I, [2024-07-04T16:12:19.107847 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  else
  fi
   62b1b69e8..2db35149f  main                    -> origin/main
 * [new branch]          add_mechanism_to_redeliver_all_webhook_events_wip -> origin/add_mechanism_to_redeliver_all_webhook_events_                          wip
 * [new branch]          fix_featured_topics_mobile -> origin/fix_featured_topics_mobile
 * [new branch]          issue/prevent-decimal-comma-integer-input-site-setting -> origin/issue/prevent-decimal-comma-integer-input                          -site-setting
   62b1b69e8..32149e6fa  tests-passed            -> origin/tests-passed
I, [2024-07-04T16:12:20.323803 #1]  INFO -- :
I, [2024-07-04T16:12:20.323954 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
      git pull
  else
  fi
I, [2024-07-04T16:12:27.761632 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-07-04T16:12:27.762404 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version                           tests-passed
I, [2024-07-04T16:12:27.848402 #1]  INFO -- :
I, [2024-07-04T16:12:27.848664 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-07-04T16:12:27.854415 #1]  INFO -- :
I, [2024-07-04T16:12:27.854638 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-07-04T16:12:27.860466 #1]  INFO -- :
I, [2024-07-04T16:12:27.860678 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-07-04T16:12:27.864396 #1]  INFO -- :
I, [2024-07-04T16:12:27.864892 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-07-04T16:12:27.932184 #1]  INFO -- :
I, [2024-07-04T16:12:27.932693 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-07-04T16:12:27.940033 #1]  INFO -- :
I, [2024-07-04T16:12:27.940385 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-07-04T16:12:27.946924 #1]  INFO -- :
I, [2024-07-04T16:12:27.947687 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,                          production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-07-04T16:12:27.956905 #1]  INFO -- :
I, [2024-07-04T16:12:27.957193 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,                          production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-07-04T16:12:27.965236 #1]  INFO -- :
I, [2024-07-04T16:12:27.966563 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-07-04T16:12:28.036448 #1]  INFO -- :
I, [2024-07-04T16:12:28.036901 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var                          /www/discourse/public"
I, [2024-07-04T16:12:28.046500 #1]  INFO -- :
I, [2024-07-04T16:12:28.047633 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}                          "
I, [2024-07-04T16:12:28.057095 #1]  INFO -- :
I, [2024-07-04T16:12:28.057405 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores}                           /var/www/discourse/tmp"
I, [2024-07-04T16:12:28.067178 #1]  INFO -- :
I, [2024-07-04T16:12:28.067805 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uplo                          ads /shared/backups /shared/tmp
I, [2024-07-04T16:12:28.243943 #1]  INFO -- :
I, [2024-07-04T16:12:28.244269 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth                           1 -xtype l -delete
I, [2024-07-04T16:12:28.248729 #1]  INFO -- :
I, [2024-07-04T16:12:28.249558 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-07-04T16:12:28.250527 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_mana                          ger.git
I, [2024-07-04T16:12:30.853995 #1]  INFO -- :
I, [2024-07-04T16:12:30.854433 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-07-04T16:12:30.939767 #1]  INFO -- :
I, [2024-07-04T16:12:30.940799 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-07-04T16:12:30.946251 #1]  INFO -- :
I, [2024-07-04T16:12:30.947639 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-07-04T16:12:30.954245 #1]  INFO -- :
I, [2024-07-04T16:12:30.954993 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-07-04T16:12:31.036718 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; }                           in /etc/nginx/conf.d/discourse.conf
I, [2024-07-04T16:12:31.038565 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.                          conf
I, [2024-07-04T16:12:31.039919 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in                           /etc/nginx/conf.d/discourse.conf
I, [2024-07-04T16:12:31.040735 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connect                          ions ; in /etc/nginx/nginx.conf
I, [2024-07-04T16:12:31.052794 #1]  INFO -- : > echo "done configuring web"
I, [2024-07-04T16:12:31.138487 #1]  INFO -- : done configuring web
I, [2024-07-04T16:12:31.139059 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH                          / { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-07-04T16:12:32.272213 #1]  INFO -- :
I, [2024-07-04T16:12:32.272415 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown disc                          ourse {} \+
I, [2024-07-04T16:12:38.379788 #1]  INFO -- :
I, [2024-07-04T16:12:38.380287 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
fi
I, [2024-07-04T16:12:38.456020 #1]  INFO -- :
I, [2024-07-04T16:12:38.456298 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn ca                          che clean'
I, [2024-07-04T16:17:52.646742 #1]  INFO -- : yarn install v1.22.22
98:signal-handler (1720109872) Received SIGTERM scheduling shutdown...
98:M 04 Jul 2024 16:17:52.663 # User requested shutdown...
98:M 04 Jul 2024 16:17:52.663 * Saving the final RDB snapshot before exiting.
I, [2024-07-04T16:17:52.653347 #1]  INFO -- : Terminating async processes
I, [2024-07-04T16:17:52.653701 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres                          :ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 36
I, [2024-07-04T16:17:52.653954 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.c                          onf pid: 98
2024-07-04 16:17:52.657 UTC [36] LOG:  received fast shutdown request
2024-07-04 16:17:52.664 UTC [36] LOG:  aborting any active transactions
2024-07-04 16:17:52.743 UTC [36] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-07-04 16:17:52.744 UTC [46] LOG:  shutting down
2024-07-04 16:17:52.860 UTC [36] LOG:  database system is shut down
98:M 04 Jul 2024 16:17:53.048 * DB saved on disk
98:M 04 Jul 2024 16:17:53.049 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean' failed with return #                          <Process::Status: pid 268 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ \"$version\" != \"tests-passed\" ]; then\n  rm -rf app/as                          sets/javascripts/node_modules\nfi", "su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'"]}
28e72690ac1f17e0226b0c7546f1e9d9f299131572ed4deacc95bc109166e028
==================== END REBUILD LOG ====================
Failed to rebuild app.
Checking your domain name . . .
Connection to **************** succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
starting up existing container
+ /usr/bin/docker start app
app
ce55082edacf   local_discourse/app                 "/sbin/boot"             4 weeks ago    Up Less than a second        app
Restarted the container.
==================== PLUGINS ====================
No non-official plugins detected.
See https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb for the official list.
Discourse version at ***************: NOT FOUND
Discourse version at localhost: NOT FOUND
==================== MEMORY INFORMATION ====================
RAM (MB): 6209
               total        used        free      shared  buff/cache   available
Mem:            5921        1978        2453         166        1489        3474
Swap:              0           0           0
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
/dev/sda3       391G   23G  349G   7% /
==================== DISK INFORMATION ====================
Disk /dev/sda: 400 GiB, 429496729600 bytes, 838860800 sectors
Disk model: QEMU HARDDISK
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 1B86FC4E-2370-48E1-8752-0E932DA55E09
Device       Start       End   Sectors  Size Type
/dev/sda1     2048      4095      2048    1M BIOS boot
/dev/sda2     4096   4194303   4190208    2G Linux filesystem
/dev/sda3  4194304 838858751 834664448  398G Linux filesystem
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [***********]:
Sending mail to *****************. . .
Testing sending to ********************** using email-smtp.us-east-1.amazonaws.com:587, username:*********************** with plain auth                          .
SMTP server connection successful.
Sending to **************. . .
Mail accepted by SMTP server.
Message-ID: 2bddc993-deed-4fbc-905e-bc692afc97d8@**************.com
If you do not receive the message, check your SPAM folder
or test again using a service like http://www.mail-tester.com/.
If the message is not delivered it is not a problem with Discourse.
Check the SMTP server logs for the above Message ID to see why it
failed to deliver the message.
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  ## Uncomment the next line to enable the IPv6 listener
  #- "templates/web.ipv6.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
  #- "templates/web.socketed.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  # - "80:80"   # http
  # - "443:443" # https
params:
  #db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  #UNICORN_WORKERS: 3
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: '**************'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: '*****************, ******************'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: email-smtp.us-east-1.amazonaws.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: *********************
  DISCOURSE_SMTP_PASSWORD: *****************************************
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: *******************    # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: *********************    # (address to send notifications from)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
  #- exec: rails r "SiteSetting.notification_email='***************'"
docker_args: |
  --network nginx_proxy_manager_default
Update: On about the tenth try, I was able to rebuild.
I don’t know if it had any effect, but I did update the docker engine to the latest version.
However, although the container is running, I am unable to access the page. It keeps telling me that the server IP address is unavailable.
I have also tried to access the site from another network on another device but to no avail.
As I mentioned, on the same VPS, I am running WordPress on the main domain, and everything is working fine. I don’t understand how Discord could stop working so suddenly.
Any ideas? I’m getting really desperate.
Problem solved.
For reasons I don’t understand, access to the site stopped working after about 24 hours after I added a TXT record to DNS.
I tried adding an A record with the server IP in forum.domain.com format, and after a while, it started working again. Previously, redirecting to a subdomain with *.domain.com worked.
Admittedly, this is a mystery to me, but the main thing is that it works now :grinning:
