Discourse بدون SSL؟ SSL في وكيل apache2
Hey there! I just set up Discourse and have some issues. I set the port to something different because I would like to use my apache2 Server as a proxy/reserse-proxy (I don’t know what’s the correct term)
When I try to start my Discourse instance, it prints this error to the logs and I can’t open Discourse:
nginx: [emerg] cannot load certificate "/shared/ssl/subdomain.website.tld.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
Is there a way to just simply disable SSL, as I usually do SSL through apache2 anyways, since I can just easily use my .crt and .key files there. If not, a) how can I fix this issue (looks like a .cer file is missing, since there is no shared/ssl folder at all; how can I obtain that since I only have .crt and .key) and b) what would I have to do in the Vhost with the SSL if it’s already done by Discourse?
This is the parts regarding the proxying and SSL I’d normally use:
ProxyPass / http://<ip-of-discourse-vps>:<http port>/
SSLEngine on
SSLCertificateFile /etc/apache2/ssl/<filename>.crt
SSLCertificateKeyFile /etc/apache2/ssl/<filename>.key
If you want to disable SSL in Discourse, edit the app.yml file (/var/discourse/containers/app.yml) and remove the templates with SSL in the name on the first lines. After that issue a rebuild (./launcher rebuild app) and after the rebuild finishes Discourse will be HTTP only.
إعجاب واحد (1)
That was very easy. I now tried that, but my page is still not accessible, but at least I have a different output in the logs now:
root@<vps-hostname>:/var/discourse# docker container logs <container-id>
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
Started runsvdir, PID is 38
ok: run: redis: (pid 48) 0s
ok: run: postgres: (pid 46) 0s
chgrp: invalid group: ‘syslog’
rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
rsyslogd: activation of module imklog failed [v8.1901.0 try https://www.rsyslog.com/e/2145 ]
supervisor pid: 51 unicorn pid: 76
Discourse doesn’t act as a “normal” container, so docker logs are useless for us.
The actual logs live in /var/discourse/shared/standalone/logs/.
But if the rebuild finished with success with zero errors, what happens when you try to curl the application in the port you set it to listen to?
إعجاب واحد (1)
Do you mean the folder “log”? Because there is no folder “logs”. In that I have the folders var-log and rails both with multiple files in them. Which ones do I have to look at?
Also, I don’t know how curl works. (I would google, but I don’t know what exactly I have to do with curl, so I don’t know what to google)
