DiscourseAi::Embeddings::Schema::MissingEmbeddingError
Hi all,
I was able now to set up the embedding endpoint, but now I´m in the next hole :frowning:
I uploaded a text file to the AI Bot Perso and asked it something about the text files contents.
What I´m getting is
So it seems, that no request has been sent, but in my logs I see a request which has been answered with 200
At the same time the AI Audit logs tell me, that there was no request:
SELECT *
FROM ai_api_audit_logs
where language_model like '%emb%'
ORDER BY created_at, language_model DESC
LIMIT 100
----> yields no results
I´m not sure what to do now :frowning:
Many thanks in advance and Greetings from Southern-Germany
WS
Can you check your logs at /logs? There should be more information there.
Hmmmmm
/var/www/discourse/plugins/discourse-ai/lib/completions/dialects/dialect.rb:147:in `trim_messages'
/var/www/discourse/plugins/discourse-ai/lib/completions/dialects/dialect.rb:83:in `translate'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:123:in `perform_completion!'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/open_ai.rb:53:in `perform_completion!'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:101:in `perform_completion!'
/var/www/discourse/plugins/discourse-ai/lib/completions/llm.rb:410:in `generate'
/var/www/discourse/plugins/discourse-ai/lib/personas/bot.rb:89:in `reply'
/var/www/discourse/plugins/discourse-ai/lib/ai_bot/playground.rb:494:in `reply_to'
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/create_ai_reply.rb:18:in `execute'
/var/www/discourse/app/jobs/base.rb:316:in `block (2 levels) in perform'
rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/app/jobs/base.rb:303:in `block in perform'
/var/www/discourse/app/jobs/base.rb:299:in `each'
/var/www/discourse/app/jobs/base.rb:299:in `perform'
sidekiq-7.3.9/lib/sidekiq/processor.rb:220:in `execute_job'
sidekiq-7.3.9/lib/sidekiq/processor.rb:185:in `block (4 levels) in process'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:180:in `traverse'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in `block in traverse'
/var/www/discourse/lib/sidekiq/discourse_event.rb:6:in `call'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in `traverse'
/var/www/discourse/lib/sidekiq/pausable.rb:131:in `call'
sidekiq-7.3.9/lib/sidekiq/job/interrupt_handler.rb:9:in `call'
sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:26:in `track'
sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:134:in `call'
sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:173:in `invoke'
sidekiq-7.3.9/lib/sidekiq/processor.rb:184:in `block (3 levels) in process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:145:in `block (6 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_retry.rb:118:in `local'
sidekiq-7.3.9/lib/sidekiq/processor.rb:144:in `block (5 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/config.rb:39:in `block in <class:Config>'
sidekiq-7.3.9/lib/sidekiq/processor.rb:139:in `block (4 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/processor.rb:281:in `stats'
sidekiq-7.3.9/lib/sidekiq/processor.rb:134:in `block (3 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_logger.rb:15:in `call'
sidekiq-7.3.9/lib/sidekiq/processor.rb:133:in `block (2 levels) in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_retry.rb:85:in `global'
sidekiq-7.3.9/lib/sidekiq/processor.rb:132:in `block in dispatch'
sidekiq-7.3.9/lib/sidekiq/job_logger.rb:40:in `prepare'
sidekiq-7.3.9/lib/sidekiq/processor.rb:131:in `dispatch'
sidekiq-7.3.9/lib/sidekiq/processor.rb:183:in `block (2 levels) in process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `handle_interrupt'
sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `block in process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `handle_interrupt'
sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `process'
sidekiq-7.3.9/lib/sidekiq/processor.rb:86:in `process_one'
sidekiq-7.3.9/lib/sidekiq/processor.rb:76:in `run'
sidekiq-7.3.9/lib/sidekiq/component.rb:10:in `watchdog'
sidekiq-7.3.9/lib/sidekiq/component.rb:19:in `block in safe_thread'
