AI embeddings backfill rake aborted
Hello :wave:
I started use Discourse Ai - OpenAi API. First I seted up it to Related Topics (text-embedding-ada-002). When I try to run the rake task for backfill. I’ve got the following error.
....rake aborted!
NoMethodError: undefined method `[]' for nil:NilClass (NoMethodError)
          response[:data].first[:embedding]
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/text_embedding_ada_002.rb:37:in `vector_from'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:145:in `generate_representation_from'
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/embeddings/database.rake:19:in `block (2 levels) in <main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:71:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:71:in `block in find_each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:138:in `block in find_in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:245:in `block in in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:229:in `loop'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:229:in `in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:137:in `find_in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:70:in `find_each'
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/embeddings/database.rake:17:in `block in <main>'
Tasks: TOP => ai:embeddings:backfill
And also see the followings in /logs.
Thanks for the help! :slightly_smiling_face:
Sounds like you’re getting a nil response.
Did you check ai embeddings enabled and add your api key to the settings?
Yeah, This is how settings looks.
Screenshot 2024-01-27 at 9.08.56
Screenshot 2024-01-27 at 9.07.17
Screenshot 2024-01-27 at 9.07.34
Screenshot 2024-01-27 at 9.08.17
The Jobs::EmbeddingsBackfill seems running but always failed with the error I mentioned in OP.
It seems it’s connected with OpenAi.
I think the problem was rate limit, I had to upgrade the tier on OpenAI and I changed the model to text-embedding-3-large. Now, I have lots of dots during rake which is a good sign. :sweat_smile: Will update this post when it’s finished.
Edit 1: So after 10 hours of dotting it closed with rake aborted
rake aborted!
Faraday::TimeoutError: Net::ReadTimeout with #<TCPSocket:(closed)> (Faraday::TimeoutError)
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-protocol-0.2.2/lib/net/protocol.rb:229:in `rbuf_fill'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-protocol-0.2.2/lib/net/protocol.rb:199:in `readuntil'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-protocol-0.2.2/lib/net/protocol.rb:209:in `readline'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http/response.rb:158:in `read_status_line'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http/response.rb:147:in `read_new'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http.rb:2342:in `block in transport_request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http.rb:2333:in `catch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http.rb:2333:in `transport_request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http.rb:2306:in `request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.3.0/lib/patches/net_patches.rb:19:in `block in request_with_mini_profiler'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.3.0/lib/mini_profiler/profiling_methods.rb:50:in `step'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.3.0/lib/patches/net_patches.rb:18:in `request_with_mini_profiler'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:113:in `block in request_with_wrapped_block'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http.rb:1570:in `start'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:112:in `request_with_wrapped_block'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:102:in `perform_request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/adapter.rb:45:in `connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:65:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/request/url_encoded.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/rack_builder.rb:152:in `build_response'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/connection.rb:444:in `run_request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/connection.rb:280:in `post'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday.rb:145:in `method_missing'
/var/www/discourse/plugins/discourse-ai/lib/inference/open_ai_embeddings.rb:18:in `perform!'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/text_embedding_3_large.rb:39:in `vector_from'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:147:in `generate_representation_from'
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/embeddings/database.rake:30:in `block (2 levels) in <main>'
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/embeddings/database.rake:28:in `block in <main>'
Caused by:
Net::ReadTimeout: Net::ReadTimeout with #<TCPSocket:(closed)> (Net::ReadTimeout)
I restarted rake. In this case it will do only the untouched topics or again the all topics? :smile:
Edit 2: The rake aborted again with the same error. But I think these processes covered the most of topics and the Jobs::EmbeddingsBackfill in Sidekiq seems run with OK now. So I think that could enough to the remaining topics :slight_smile:
