גיבוי משלו של Discourse עם Redis ו-pgSQL חיצוניים - האם זה נחוץ?
Hi guys.
As per the subject - when those are taken of externally, outside of Discourse - can internal backups be “disabled” completely? Thanks.
If you’re backing up the database some other way then you don’t need them. You can just disable them.
