Discouse with NginX reverse proxy - Cannot log in
In a discussion titled “Discourse with NginX reverse proxy - Cannot log in,” user stum reports that users cannot maintain a session after logging in when Discourse is behind an NGINX reverse proxy, despite successful-looking logs. The issue disappears when NGINX is bypassed. They share their NGINX configuration, which initially lacks the X-Forwarded-Proto header. michaeld suggests adding proxy_set_header X-Forwarded-Proto https; to fix it. stum confirms adding the directive but still experiences the issue. Later, 1vernit3 asks if the problem was resolved, and Moin notes that stum appears to have solved it in a separate topic: Users can’t log in after NGINX setup. The core issue revolves around proper proxy header configuration for Discourse to recognize secure connections behind NGINX.
When running an NGINX reverse proxy in front of Discourse you cannot log into the site. After submitting your credentials you are taken back to the index page and do not have a session. No errors are displayed and it seems from the logs that the login was successfull.
Creating scope :open. Overwriting existing method Poll.open.
Started GET "/" for 10.42.4.0 at 2021-10-05 14:24:41 +1300
Processing by ListController#latest as HTML
  Rendered list/list.erb within layouts/application (Duration: 8.8ms | Allocations: 1141)
  Rendered layout layouts/application.html.erb (Duration: 22.9ms | Allocations: 3194)
Completed 200 OK in 189ms (Views: 23.9ms | ActiveRecord: 0.0ms | Allocations: 21280)
Started GET "/session/csrf" for 10.42.4.0 at 2021-10-05 14:24:52 +1300
Processing by SessionController#csrf as JSON
Completed 200 OK in 384ms (Views: 0.3ms | ActiveRecord: 0.0ms | Allocations: 5303)
Started POST "/session" for 10.42.4.0 at 2021-10-05 14:24:52 +1300
Processing by SessionController#create as */*
  Parameters: {"login"=>"admin", "password"=>"[FILTERED]", "second_factor_method"=>"1", "timezone"=>"Pacific/Auckland"}
Completed 200 OK in 1043ms (Views: 0.3ms | ActiveRecord: 0.0ms | Allocations: 147364)
Started POST "/login" for 10.42.4.0 at 2021-10-05 14:24:54 +1300
Processing by StaticController#enter as HTML
  Parameters: {"username"=>"admin", "password"=>"[FILTERED]", "redirect"=>"https://forum.test.financefeast.io/"}
Redirected to https://forum.test.financefeast.io/
Completed 302 Found in 3ms (ActiveRecord: 0.0ms | Allocations: 710)
Started GET "/" for 10.42.4.0 at 2021-10-05 14:24:54 +1300
  Rendered list/list.erb within layouts/application (Duration: 46.7ms | Allocations: 11808)
  Rendered layout layouts/application.html.erb (Duration: 308.6ms | Allocations: 53646)
Completed 200 OK in 1123ms (Views: 311.1ms | ActiveRecord: 0.0ms | Allocations: 167190)
Tested without the NGIX reverse proxy in front of discourse and logins are fine. Is there any specific configuration for NGINX to get this working?
This is the NGINX conf:
server {
    listen 80;
    server_tokens off;
    server_name forum.test.financefeast.io;
    location / {
	 return 301 https://$host$request_uri;
    location ~* \.(jpg|jpeg|png|gif|ico|css|js)$ {
         expires 30m;
         add_header Pragma public;
         add_header Cache-Control "public";
server {
    ssl_certificate /etc/nginx/certs/test.financefeast.io-bundle.crt;
    ssl_certificate_key /etc/nginx/certs/test.financefeast.io.key;
    listen 443 ssl;
    location / {
	add_header 'Access-Control-Allow-Origin' "$http_origin";
	add_header 'Access-Control-Allow-Methods' 'GET, POST, OPTIONS, DELETE, PUT';
	add_header 'Access-Control-Allow-Credentials' 'true';
	add_header 'Access-Control-Allow-Headers' 'User-Agent,Keep-Alive,Content-Type';
	proxy_set_header Host $http_host;
	proxy_set_header X-Real-IP $remote_addr;
	proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
	proxy_read_timeout 90;
	proxy_http_version 1.1;
 	proxy_buffers 8 32k;
	proxy_buffer_size 64k;
	proxy_pass   https://kube_lb;
You forgot to add a header:
will fix this issue.
I’ve added that directive but still getting the same issue. Conf looks like this now:
server {
    listen 80;
    server_tokens off;
    location / {
         expires 30m;
server {
    listen 443 ssl;
    location / {
Did you ever manage to solve this I am getting this problem too.
Looks like you have solved your problem in the new topic you created:
