Dismissing upgrade available notifications leads to 422 errors
Self explanatory, click the dismiss button and error 422
Installed 2025.12.0-latest(52ab90911d)
From error logs
Message (6 copies reported)
ActiveRecord::RecordInvalid (Validation failed: Target can't be blank)
app/models/problem_check_tracker.rb:47:in `reset'
app/services/admin_notices/dismiss.rb:40:in `reset_problem_check'
lib/service/base.rb:181:in `instance_exec'
lib/service/base.rb:181:in `run_step'
lib/service/base.rb:159:in `block in call'
lib/service/base.rb:190:in `with_runtime'
lib/service/base.rb:159:in `call'
lib/service/base.rb:288:in `block (2 levels) in run_step'
lib/service/base.rb:288:in `each'
lib/service/base.rb:288:in `block in run_step'
lib/service/base.rb:288:in `run_step'
lib/service/base.rb:547:in `block in run!'
lib/service/base.rb:547:in `each'
lib/service/base.rb:547:in `run!'
lib/service/base.rb:540:in `run'
lib/service/base.rb:392:in `call'
lib/service/runner.rb:152:in `result'
lib/service/runner.rb:137:in `call'
lib/service/runner.rb:132:in `call'
lib/service/base.rb:393:in `call'
app/controllers/admin/admin_notices_controller.rb:5:in `destroy'
app/controllers/application_controller.rb:440:in `block in with_resolved_locale'
app/controllers/application_controller.rb:440:in `with_resolved_locale'
app/controllers/application_controller.rb:1073:in `ensure_dont_cache_page'
lib/middleware/omniauth_bypass_middleware.rb:35:in `call'
lib/middleware/crawler_hooks.rb:11:in `call'
lib/middleware/anonymous_cache.rb:415:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
lib/middleware/default_headers.rb:13:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:376:in `call'
Backtrace
activerecord (8.0.4) lib/active_record/validations.rb:87:in `raise_validation_error'
activerecord (8.0.4) lib/active_record/validations.rb:54:in `save!'
activerecord (8.0.4) lib/active_record/transactions.rb:365:in `block in save!'
activerecord (8.0.4) lib/active_record/transactions.rb:417:in `block (2 levels) in with_transaction_returning_status'
activerecord (8.0.4) lib/active_record/connection_adapters/abstract/database_statements.rb:357:in `transaction'
activerecord (8.0.4) lib/active_record/transactions.rb:413:in `block in with_transaction_returning_status'
activerecord (8.0.4) lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in `with_connection'
activerecord (8.0.4) lib/active_record/connection_handling.rb:312:in `with_connection'
activerecord (8.0.4) lib/active_record/transactions.rb:409:in `with_transaction_returning_status'
activerecord (8.0.4) lib/active_record/transactions.rb:365:in `save!'
activerecord (8.0.4) lib/active_record/suppressor.rb:56:in `save!'
activerecord (8.0.4) lib/active_record/persistence.rb:579:in `block in update!'
activerecord (8.0.4) lib/active_record/persistence.rb:577:in `update!'
activerecord (8.0.4) lib/active_record/connection_adapters/abstract/transaction.rb:626:in `block in within_new_transaction'
activesupport (8.0.4) lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
activerecord (8.0.4) lib/active_record/connection_adapters/abstract/transaction.rb:623:in `within_new_transaction'
activerecord (8.0.4) lib/active_record/connection_adapters/abstract/database_statements.rb:367:in `within_new_transaction'
activerecord (8.0.4) lib/active_record/connection_adapters/abstract/database_statements.rb:359:in `transaction'
activerecord (8.0.4) lib/active_record/transactions.rb:233:in `block in transaction'
activerecord (8.0.4) lib/active_record/connection_adapters/abstract/connection_pool.rb:422:in `with_connection'
activerecord (8.0.4) lib/active_record/transactions.rb:232:in `transaction'
<internal:kernel>:90:in `tap'
actionpack (8.0.4) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (8.0.4) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (8.0.4) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (8.0.4) lib/active_support/callbacks.rb:120:in `block in run_callbacks'
i18n (1.14.7) lib/i18n.rb:353:in `with_locale'
activesupport (8.0.4) lib/active_support/callbacks.rb:129:in `block in run_callbacks'
activesupport (8.0.4) lib/active_support/callbacks.rb:140:in `run_callbacks'
actionpack (8.0.4) lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/instrumentation.rb:76:in `block in process_action'
activesupport (8.0.4) lib/active_support/notifications.rb:210:in `block in instrument'
activesupport (8.0.4) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (8.0.4) lib/active_support/notifications.rb:210:in `instrument'
actionpack (8.0.4) lib/action_controller/metal/instrumentation.rb:75:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (8.0.4) lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack (8.0.4) lib/abstract_controller/base.rb:152:in `process'
actionview (8.0.4) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (4.0.1) lib/mini_profiler/profiling_methods.rb:90:in `block in profile_method'
actionpack (8.0.4) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (8.0.4) lib/action_controller/metal.rb:335:in `dispatch'
actionpack (8.0.4) lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack (8.0.4) lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack (8.0.4) lib/action_dispatch/routing/mapper.rb:32:in `block in <class:Constraints>'
actionpack (8.0.4) lib/action_dispatch/routing/mapper.rb:62:in `serve'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:126:in `each'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack (8.0.4) lib/action_dispatch/routing/route_set.rb:908:in `call'
rack (2.2.21) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.21) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.21) lib/rack/head.rb:12:in `call'
actionpack (8.0.4) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.21) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.21) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/cookies.rb:706:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport (8.0.4) lib/active_support/callbacks.rb:100:in `run_callbacks'
actionpack (8.0.4) lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/show_exceptions.rb:32:in
Failed to handle exception in exception app middleware : ActiveRecord::RecordInvalid : Validation failed: Target can't be blank
Backtrace
activerecord-8.0.4/lib/active_record/validations.rb:87:in `raise_validation_error'
activerecord-8.0.4/lib/active_record/validations.rb:54:in `save!'
activerecord-8.0.4/lib/active_record/transactions.rb:365:in `block in save!'
activerecord-8.0.4/lib/active_record/transactions.rb:417:in `block (2 levels) in with_transaction_returning_status'
activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:357:in `transaction'
activerecord-8.0.4/lib/active_record/transactions.rb:413:in `block in with_transaction_returning_status'
activerecord-8.0.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in `with_connection'
activerecord-8.0.4/lib/active_record/connection_handling.rb:312:in `with_connection'
activerecord-8.0.4/lib/active_record/transactions.rb:409:in `with_transaction_returning_status'
activerecord-8.0.4/lib/active_record/transactions.rb:365:in `save!'
activerecord-8.0.4/lib/active_record/suppressor.rb:56:in `save!'
activerecord-8.0.4/lib/active_record/persistence.rb:579:in `block in update!'
activerecord-8.0.4/lib/active_record/persistence.rb:577:in `update!'
/var/www/discourse/app/models/problem_check_tracker.rb:47:in `reset'
/var/www/discourse/app/services/admin_notices/dismiss.rb:40:in `reset_problem_check'
/var/www/discourse/lib/service/base.rb:181:in `instance_exec'
/var/www/discourse/lib/service/base.rb:181:in `run_step'
/var/www/discourse/lib/service/base.rb:159:in `block in call'
/var/www/discourse/lib/service/base.rb:190:in `with_runtime'
/var/www/discourse/lib/service/base.rb:159:in `call'
/var/www/discourse/lib/service/base.rb:288:in `block (2 levels) in run_step'
/var/www/discourse/lib/service/base.rb:288:in `each'
/var/www/discourse/lib/service/base.rb:288:in `block in run_step'
activerecord-8.0.4/lib/active_record/connection_adapters/abstract/transaction.rb:626:in `block in within_new_transaction'
activesupport-8.0.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
activerecord-8.0.4/lib/active_record/connection_adapters/abstract/transaction.rb:623:in `within_new_transaction'
activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:367:in `within_new_transaction'
activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:359:in `transaction'
activerecord-8.0.4/lib/active_record/transactions.rb:233:in `block in transaction'
activerecord-8.0.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:422:in `with_connection'
activerecord-8.0.4/lib/active_record/transactions.rb:232:in `transaction'
/var/www/discourse/lib/service/base.rb:288:in `run_step'
/var/www/discourse/lib/service/base.rb:547:in `block in run!'
/var/www/discourse/lib/service/base.rb:547:in `each'
/var/www/discourse/lib/service/base.rb:547:in `run!'
/var/www/discourse/lib/service/base.rb:540:in `run'
/var/www/discourse/lib/service/base.rb:392:in `call'
/var/www/discourse/lib/service/runner.rb:152:in `result'
/var/www/discourse/lib/service/runner.rb:137:in `call'
/var/www/discourse/lib/service/runner.rb:132:in `call'
/var/www/discourse/lib/service/base.rb:393:in `call'
/var/www/discourse/app/controllers/admin/admin_notices_controller.rb:5:in `destroy'
actionpack-8.0.4/lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack-8.0.4/lib/abstract_controller/base.rb:215:in `process_action'
actionpack-8.0.4/lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack-8.0.4/lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport-8.0.4/lib/active_support/callbacks.rb:120:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:440:in `block in with_resolved_locale'
i18n-1.14.7/lib/i18n.rb:353:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:440:in `with_resolved_locale'
activesupport-8.0.4/lib/active_support/callbacks.rb:129:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:1073:in `ensure_dont_cache_page'
activesupport-8.0.4/lib/active_support/callbacks.rb:140:in `run_callbacks'
actionpack-8.0.4/lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack-8.0.4/lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack-8.0.4/lib/action_controller/metal/instrumentation.rb:76:in `block in process_action'
activesupport-8.0.4/lib/active_support/notifications.rb:210:in `block in instrument'
activesupport-8.0.4/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport-8.0.4/lib/active_support/notifications.rb:210:in `instrument'
actionpack-8.0.4/lib/action_controller/metal/instrumentation.rb:75:in `process_action'
actionpack-8.0.4/lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord-8.0.4/lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack-8.0.4/lib/abstract_controller/base.rb:152:in `process'
actionview-8.0.4/lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler-4.0.1/lib/mini_profiler/profiling_methods.rb:90:in `block in profile_method'
actionpack-8.0.4/lib/action_controller/metal.rb:252:in `dispatch'
actionpack-8.0.4/lib/action_controller/metal.rb:335:in `dispatch'
actionpack-8.0.4/lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack-8.0.4/lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack-8.0.4/lib/action_dispatch/routing/mapper.rb:32:in `block in <class:Constraints>'
actionpack-8.0.4/lib/action_dispatch/routing/mapper.rb:62:in `serve'
actionpack-8.0.4/lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack-8.0.4/lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack-8.0.4/lib/action_dispatch/journey/router.rb:126:in `each'
actionpack-8.0.4/lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack-8.0.4/lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack-8.0.4/lib/action_dispatch/routing/route_set.rb:908:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:35:in `call'
/var/www/discourse/lib/middleware/crawler_hooks.rb:11:in `call'
rack-2.2.21/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.21/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.21/lib/rack/head.rb:12:in `call'
actionpack-8.0.4/lib/action_dispatch/http/permissions_policy.rb:38:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:415:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.21/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.21/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-8.0.4/lib/action_dispatch/middleware/cookies.rb:706:in `call'
actionpack-8.0.4/lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport-8.0.4/lib/active_support/callbacks.rb:100:in `run_callbacks'
actionpack-8.0.4/lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack-8.0.4/lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack-8.0.4/lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster-2.20.1/lib/logster/middleware/reporter.rb:40:in `call'
/var/www/discourse/lib/middleware/default_headers.rb:13:in `call'
railties-8.0.4/lib/rails/rack/logger.rb:41:in `call_app'
railties-8.0.4/lib/rails/rack/logger.rb:29:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-8.0.4/lib/action_dispatch/middleware/request_id.rb:34:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:23:in `call'
rack-2.2.21/lib/rack/method_override.rb:24:in `call'
actionpack-8.0.4/lib/action_dispatch/middleware/executor.rb:16:in `call'
rack-2.2.21/lib/rack/sendfile.rb:127:in `call'
rack-mini-profiler-4.0.1/lib/mini_profiler.rb:191:in `call'
/var/www/discourse/lib/middleware/processing_request.rb:12:in `call'
message_bus-4.4.1/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:376:in `call'
actionpack-8.0.4/lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties-8.0.4/lib/rails/engine.rb:535:in `call'
railties-8.0.4/lib/rails/railtie.rb:226:in `public_send'
railties-8.0.4/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.21/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.21/lib/rack/urlmap.rb:58:in `each'
