tanmaya
(tanmaya)
8 באוגוסט, 2017, 11:55am
1
I see below error when trying to to upgrade a discourse forum from 1.8 beta 4 to 1.9 beta5:
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:22:in `load'
/usr/local/bin/bundle:22:in `<main>'
ActiveRecord::StatementInvalid: PG::NotNullViolation: ERROR: null value in column "updated_at" violates not-null constraint
DETAIL: Failing row contains (1, 31, xxxxx, xxxxx, null, f, t, null, 2016-09-04 17:05:55.130532, 2016-09-04 17:05:55.130532, null).
: INSERT INTO user_auth_tokens(user_id, auth_token, prev_auth_token, legacy, created_at, rotated_at)
SELECT id, auth_token, auth_token, true, auth_token_updated_at, auth_token_updated_at
FROM users
WHERE auth_token_updated_at IS NOT NULL AND auth_token IS NOT NULL
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.5/lib/patches/db/pg.rb:90:in `async_exec'
Now this forum is down. While I do have backup, I want to know if there is a quick action I can take to resolve this, before I attempt restore?
Exact same problem here. I tried to upgrade from 1.8.0 beta 4 to 1.9.0 beta 5 using the admin interface, but it torched my Discourse install and I wasn’t able to even launch it after that, or rebuild, or anything. So I did this:
restored my VPS from a backup back to Discourse working 1.8.0b4
exported backup via Discourse admin interface
set up a new VPS using Ubuntu 16.04 LTS, and fresh Discourse 1.9.0b5 install
tried restoring from my Discourse backup (from 1.8.0b4), but restore failed with same error message:
[2017-08-08 23:41:26] Migrating the database...
[2017-08-08 23:41:26] EXCEPTION: An error has occurred, this and all later migrations canceled:
DETAIL: Failing row contains (1, 746, 6346895213c8a22b91ebf4b6aa1d63da, 6346895213c8a22b91ebf4b6aa1d63da, null, f, t, null, 2017-05-30 21:58:27.289695, 2017-05-30 21:58:27.289695, null).
FROM users
[2017-08-08 23:41:26] /var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.5/lib/patches/db/pg.rb:93:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.5/lib/patches/db/pg.rb:93:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/postgresql/database_statements.rb:155:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract_adapter.rb:484:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract_adapter.rb:478:in `log'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/postgresql/database_statements.rb:154:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:665:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:634:in `block in say_with_time'
/usr/local/lib/ruby/2.3.0/benchmark.rb:293:in `measure'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:634:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:654:in `method_missing'
/var/www/discourse/db/migrate/20170124181409_add_user_auth_tokens.rb:31:in `up'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:611:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:7:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:6:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:592:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:591:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/connection_pool.rb:292:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:590:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:768:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:1023:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:1069:in `block in ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/transaction.rb:184:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/transactions.rb:220:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:1069:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:1022:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:984:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:980:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:980:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:823:in `up'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/migration.rb:807:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/tasks/database_tasks.rb:139:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/railties/databases.rake:44:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/lib/rake/task.rb:250:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/lib/rake/task.rb:250:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/lib/rake/task.rb:250:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/lib/rake/task.rb:194:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/2.3.0/monitor.rb:214:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/lib/rake/task.rb:187:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/lib/rake/task.rb:180:in `invoke'
/var/www/discourse/lib/backup_restore/restorer.rb:342:in `migrate_database'
/var/www/discourse/lib/backup_restore/restorer.rb:52:in `run'
/var/www/discourse/lib/backup_restore/backup_restore.rb:163:in `block in start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `fork'
/var/www/discourse/lib/backup_restore/backup_restore.rb:160:in `start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:19:in `restore!'
/var/www/discourse/app/controllers/admin/backups_controller.rb:101:in `restore'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionview-4.2.9/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.5/lib/mini_profiler/profiling_methods.rb:102:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/mapper.rb:49:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:189:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:167:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/conditionalget.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.7/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:17:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.5/lib/mini_profiler/profiler.rb:282:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.2/lib/message_bus/rack/middleware.rb:62:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:702:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `<main>'
tanmaya
(tanmaya)
9 באוגוסט, 2017, 9:18am
3
Since this issue kills forums, and not even leave Discourse level backups as a usable option, is there a way to escalate this matter? @sam @codinghorror
tgxworld
(Alan Tan)
9 באוגוסט, 2017, 11:53am
4
@tanmaya Can you try rebuilding again with
committed 11:52AM - 09 Aug 17 UTC
3 לייקים
tanmaya
(tanmaya)
9 באוגוסט, 2017, 2:26pm
5
Worked great. Thanks much for the quick help!
לייק 1
