خطأ في Docker عند ترقية سطر الأوامر (Postgres؟)
Discourse on Ubuntu 16.04.6 running ok since one year. Discourse is the only docker container active. When trying to upgrade, I get an error related to postgres:
/var/discourse> cat a.txt
Fordere an von origin
Launcher is up-to-date
cd /pups && git pull && /pups/bin/pups --stdin
Already up-to-date.
FAILED
Pups::ExecError: socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit
&& echo postgres already running stop container ; exit 1 failed with return #<Process::St
us: pid 46 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params "socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5
2 || exit 0 && echo postgres already running stop container ; exit 1"
c8bfea4f2b676b6f936890f6a301eb400b1971a7cfc99d7aaae373d02520c9cf
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may
e more than one
/var/discourse>
It is likely the docker service is out of date and needs to be updated.
apt tells me it is already latest version (and all other ubuntu stuff is current)
docker-ce ist schon die neueste Version (5:18.09.6~3-0~ubuntu-xenial).
Ok good then it looks like Postgres is your problem. Have you tried rebooting and the rebuilding from command line again?
Rebuilding alone did not work. Fine after
  • explicitly stop container
  • remove image (required!)
  • rebuild
Thanks
