I keep up with updates and when I did the docker today then went to do the rest I got this
which is new to me,
all went good with putty but wanted to post and ask, no worries?
which is new to me,
That is necessary a couple of times a year. We also made a note about it on the latest release topic.
which I’ve neglected to read this time
Thank you for the answer
Sorry I got the same message (which i knew from some months ago) so no problem on this, but this time when I run:
cd /var/discourse
git pull
./launcher rebuild app
I get this Error:
So I red this thread:
(which is closed so I cant reply)
and I am referring to:
I have rebootet the server from:
But everytime I boot the machine back up and try to run
cd /var/discourse
git pull
It triggers the very same Error.
If you think I should open a new Thread for this please just move my Post into a new one. I dont want to spam the board with new threads, but apparently can not reply on the other closed Thread and its “solution” did not work for me
my Setup is
You have two problems, first, with Git
You are in 'detached HEAD' state. You can look around, make experimental
Somehow you have made local code changes that conflict.
xec failed with the params "socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1"
It also looks like postgres is having problems on your instance. Did you install using the standard method, the only method we support?
Yes like stated here:
But I already managed to solve the problem.
I stopped the container and run the commands again after a reboot.
Notice that I had to turn off autostart for this container. Dunno why but then it worked.
