root@forum:/var/discourse# cd /var/discourse
root@forum:/var/discourse# git pull
Already up to date.
root@forum:/var/discourse# ./discourse-setup
Failed to find docker or docker.io on your PATH.
Enter to install Docker from https://get.docker.com/ or Ctrl+C to exit
./discourse-setup: line 134: curl: command not found
Still failed to find docker or docker.io on your PATH.
Docker install failed. Quitting.
You’ll need to install docker, or at least install curl so that Discourse-setup has a chance.
apt install -y curl
Should do it if you’re using Ubuntu or debian. If you’re not using one of those you’ll have to use Google to figure out how.
Thank you, God bless.
