Docker launcher fails with message «/pups/lib/pups/cli.rb:15:in `split': invalid byte sequence in US-ASCII» then container *.yml file contains non-ASCII symbols
Non-ASCII symbols in container *.yml file are needed for:
But now it fails:
root /usr/local/discourse # ./launcher rebuild app
Ensuring discourse docker is up to date
Fetching origin
Discourse Docker is up-to-date
Stopping old container
  • /usr/bin/docker stop -t 10 app
    app
    cd /pups && git pull && /pups/bin/pups --stdin
    From GitHub - discourse/pups: Simple yaml based bootstrapper for Linux machines
    8d972ab..7d741e1 master → origin/master
    Updating 8d972ab..7d741e1
    Fast-forward
    README.md | 16 ++++++++++++++++
    1 file changed, 16 insertions(+)
    I, [2015-05-25T15:15:11.528613 #41] INFO – : Loading --stdin
    /pups/lib/pups/cli.rb:15:in split': invalid byte sequence in US-ASCII (ArgumentError) from /pups/lib/pups/cli.rb:15:in run’
    from /pups/bin/pups:8:in `’
    06ed9e81b57dd6311fbe5b8d4e81228db044dc677c72ec25110952c757964ac4
    FAILED TO BOOTSTRAP
Maybe it can be fixed in pups/lib/pups/cli.rb at master · discourse/pups · GitHub
by adding the line like
conf = conf.encode("UTF-8")
before the line
split = conf.split("_FILE_SEPERATOR_")
4 Mi Piace
I would not force encoding, instead amend launcher to pass the utf text.
How exactly to go about this?
Someone had an “é” in their hostname earlier today and the same error came up.
I tried changing a few settings within the yaml file to france, but same error occurred.
Which setting to change, and where?
I tried to change:
from .english to france
and
to fr_FR.UTF-8
separately and in combination.
Is there no easy answer here? I tried hacking in the launcher some as well, no dice.
I can convert the format in php before it ever touches the yaml/launcher, but would think this a last option. Am advertising in other languages across the globe, and would rather offer than limit.
Non è più possibile riprodurlo.
