Rebuild of Discourse fails due to spaces in YAML file
סיכום מבוסס בינה מלאכותית
The user pgeschke encountered a YAML syntax error during a Discourse rebuild, traced to misaligned whitespace in the app.yml file after attempting to modify upload limits. mpalmer suggested checking the file with yamllint.com, but the issue persisted. pgeschke clarified the problem was not due to changes made but rather a missing indentation—specifically, two leading spaces were missing at the end of the file. The error occurred at line 10, but the actual issue was unrelated to the content at that line, highlighting YAML’s sensitivity to formatting. pgeschke resolved the issue by correcting the indentation, emphasizing the importance of precise formatting in YAML files.
Hey all!
I installed discourse as per How To Install Discourse on Ubuntu 16.04 | DigitalOcean and then tried modifying upload limits using Change the maximum attachment/upload size.
Unfortunately this lead me to an error
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
(<unknown>): did not find expected key while parsing a block mapping at line 10 column 1 -e
LANG=en_US.UTF-8
YAML syntax error. Please check your containers/*.yml config files.
After which i reverted the changes made and still tried a rebuild, causing the same error. Can anyone hint me to here i need a change?
Thanks!
p.
Your containers/app.yml is broken. Probably at or around line 10. Whatever you reverted, it doesn’t seem like you did it correctly.
Hey Matt. Nothing has been changed around that area.
There is a section for custom code, as stated on the second link.
All lined added were removed, so im at the state i was before.
i only ran the rebuild again, because i was wondering if it really was anything i changed that caused it, but since the error persists after reverting, i guess not.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "1024MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
   #DISCOURSE_DEFAULT_LOCALE: de
  UNICORN_WORKERS: 4
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: XXX
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'XXX'
Did you try visiting yamllint.com as suggested in the header comment? The alignment on the comment underneath the “LANG” line seems off; I don’t recall if misaligned comments cause problems, but it wouldn’t surprise me, because YAML is a picky bugger like that.
I did just now:
Valid YAML!
Well now, you’ve got yourself a stone cold whodunnit on your hands. Since it was working before you made the changes, it stands to reason that the changes you made are the problem, and you’ve just lost track of exactly what got changed. It’s probably best just to blow away this install and start again with a fresh install, and next time take backups of config files before you change them, so you can cleanly revert if necessary (and get an exact list of changes made using diff).
Urgh. Somehow i dont think that is the case :slight_smile:
“It was working before” is not exactly true, since i never tried to rebuild the app prior to inserting the recommended changes.
Can someone provide me a app.yml of a default installation?
The bottom line was missing 2 leading spaces. So basically wherever the parser was seeing the error had absolutely nothing to do with it :slight_smile:
Thanks anyways.
