أحاول التنفيذ وفقًا للدليل، لكنني لم أستطع النجاح.
على سبيل المثال:
\u003ci class="fab fa-adobe"\u003e\u003c/i\u003e
أدخل الوسم هنا وهنا، لكن للأسف لا يعمل. لقد قمت بتفعيل المكون بشكل صحيح.
على سبيل المثال:
The correct syntax should be only fab-adobe, however I think the problem is only that the Adobe icon has been added from the version 5.6 of Fontawesome and we are still at the 5.5 version.
@pmusaraj can you confirm?
We are on Font Awesome 5.11.2, the adobe icon should work if you use fab-adobe in both settings.
Cool.
So the correct syntax is tag1,fab-adobe in the tag icon list and fab-adobe in the svg icon theme settings.
Since this component already has the setting svg icon you can skip the svg icon subnet site setting step.
