붙여넣고 싶은 내용:
PS /> coredumpctl debug
PID: 19088 (org_kde_powerde)
UID: 1000 (RokeJulianLockhart)
GID: 1000 (RokeJulianLockhart)
Signal: 11 (SEGV)
Timestamp: Sat 2026-09-12 23:23:40 BST (9min ago)
Command Line: /usr/libexec/org_kde_powerdevil
Executable: /usr/libexec/org_kde_powerdevil
Control Group: /user.slice/user-1000.slice/user@1000.service/background.slice/plasma-powerdevil.service
Unit: user@1000.service
User Unit: plasma-powerdevil.service
Slice: user-1000.slice
Owner UID: 1000 (RokeJulianLockhart)
Boot ID: 6c3ba3ed07c444fb9aed3e98e9c6523c
Machine ID: 427143abd98046a4b2c750e2ca0036ea
Hostname: beedell.rokeJulianLockhart.skqy07
Storage: /var/lib/systemd/coredump/core.org_kde_powerde.1000.6c3ba3ed07c444fb9aed3e98e9c6523c.19088.1789251820000000.zst (present)
Size on Disk: 9.5K
Message: Process 19088 (org_kde_powerde) of user 1000 dumped core.
GNU gdb (Fedora Linux) 17.2-2.fc44
Copyright (C) 2025 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/libexec/org_kde_powerdevil...
This GDB supports auto-downloading debuginfo from the following URLs:
<https://debuginfod.elfutils.org/>
<ima:enforcing>
<https://debuginfod.fedoraproject.org/>
<ima:ignore>
Enable debuginfod for this session? (y or [n]) y
--Type <RET> for more, q to quit, c to continue without paging--c
Debuginfod has been enabled.
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.
Reading symbols from /home/RokeJulianLockhart/.cache/debuginfod_client/a7e7ebed7e749317eeee0ab866b9c3e5a7bc682c/debuginfo...
❌ "/var/tmp/coredump-iPdn8g" is not a core dump: file format not recognized
(gdb) bt
❌ No stack.
(gdb)
다음과 같이 작성하면:
~~~console
…그 안에 붙여넣으면 다음과 같이 변형됩니다:
PID: **19088** (org_kde_powerde)
Signal: 11 (SEGV)
Executable: **/usr/libexec/org_kde_powerdevil**
Size on Disk: 9.5K
**GNU gdb (Fedora Linux) 17.2-2.fc44**
Type "**show copying**" and "**show warranty**" for details.
Type "**show configuration**" for configuration details.
For help, type "**help**".
Type "**apropos word**" to search for commands related to "word"...
<ima:enforcing>
<ima:ignore>
Enable debuginfod for this session? (y or \[n\]) y
(gdb) bt
❌ No stack.
(gdb)
그러나 ```을 사용하면 이러한 자동 변형을 방지할 수 있습니다.
