Does the current discourse support "partial match search" in topic's title?
It doesn’t work on my discourse.
For example, my discourse has the title, “approximately.”
When I search with “approx”, the suggested search results will show up.
When I search with “mately”, the suggested search results will not show up.
My discourse is old, v1.6.0.beta10 +9.
It does not matter, you need to upgrade ASAP, many exploits were patched since 1.6…
4 לייקים
This is by design, common way to have search the way you are describing is to use trigrams. At the moment there are no plans for a trigram based search.
לייק 1
