Does anyone know of a plugin or mod that will keep track of which user clicked a link or downloaded an attached file?
The discussion revolves around tracking which users click links or download files in Discourse. AndyBr asks for a plugin or mod to log individual user downloads and link clicks. Lilly suggests Google Tag Manager for this, noting that Discourse doesnât track individual clicks by default, though it does track link clicks via the topic_link_clicks table, which includes a user_id. JammyDodger provides an SQL query using the DataExplorer plugin to retrieve click data for a specific post, which AndyBr confirms works. AndyBr proposes a plugin to display who clicked links in a post, with hover-over details and a copy icon, similar to reaction buttons. pfaffman notes this is feasible by modifying the topic serializer. Lilly suggests posting in Marketplace to attract developers.
i suspect you probably need to use google tag manager for this. Discourse itself doesnât track individual userâs clicks (it tracks topic views and link click counts by users as a whole) and i havenât seen a plugin that does this sort of tracking at the individual user level.
TY. Was hoping someone had created something like this that works with the latest DiscourseâŠ
Donât really need the restrictions, just the logging of who downloaded what.
If you have a budget you can post in Marketplace or contact me. I have no idea what it would take without looking at the code. Links get tracked, so it should be possible to also log who clicked them. Downloads will likely be harder.
FWIW Thereâs the topic_link_clicks table with a bit more info in, though I think it has the limitation of only counting direct clicks and not eg. âright click and openâ.
oh i didnât think it tracked the user info but i see now there is a user_id field in the table
interesting ![]()
Oh!
Could someone kind person with more SQL chops than me create a query that would list the post, link and username?
(I have the DataExplorer Plugin for running queries)
Something like this should do it:
-- [params]
-- int :topic
-- int :post_number
SELECT
tl.post_id,
tl.url,
tlc.user_id
FROM topic_link_clicks tlc
JOIN topic_links tl ON tl.id = tlc.topic_link_id
JOIN posts p ON p.id = tl.post_id
WHERE p.topic_id = :topic
AND p.post_number = :post_number
AND tlc.user_id IS NOT NULL
ORDER BY tlc.id
You can use the topic id and post number from the address bar to pull up all the users who clicked on the links in a specific post (you may need to refresh the page once you paste it in to get the parameter input boxes to show up the first time).
Hopefully that helps. ![]()
TY. Works fine!
Seems to me that a plugin that would show who clicked any link in a post would be quite easy to make (for someone that knows how to make plugins)
Ideally, hovering over the number would pop-up the list of who clicked, with a little âcopyâ icon in the corner! ![]()
this sounds similar to some of the like/reaction button functionality
Thatâs possible, youâd need to add that list to the topic serializer.
Anyone feel like having a crack at it?
you may want to post this in Marketplace to get some interest for developers
