DuckDuckGo Search Suggestions
The discussion DuckDuckGo Search Suggestions revolves around replacing Google with DuckDuckGo as the suggested search system in Discourse. notriddle created a theme component to achieve this, which can be found on GitHub.
wolftune identified several text strings that need to be customized to stop mentioning Google, including js.search.or_search_google and page_not_found.search_google. notriddle explained that 404 handling in Discourse is complex and requires special attention.
The theme component was updated to handle 404 pages correctly, and notriddle added a commit to rewrite the form and make it work both within and outside the Ember app. However, as wolftune pointed out, Google is no longer used on 404 pages, so the theme component was updated to leave these pages alone.
The conversation also touched on the fact that Google is still the default for extra searching when internal searches fail, and many users, including Zup, satonotdead, and Jonathan5, expressed a desire to change this to DuckDuckGo or make it a site setting. notriddle has pushed an update to use a plugin outlet, but this requires the outlet to be added to Discourse itself.
Solves Is there a way to suggest DuckDuckGo instead of Google for failed search UI?.
A Discourse theme component to use DuckDuckGo as the suggested search system, instead of Google!
p.s. You’ll probably want to customize some of the text strings to stop mentioning Google, too.
Here’s what I’ve noted to be the places to alter the text:
  • js.search.or_search_google
  • js.search.search_google
  • js.search.search_google_button
  • page_not_found.search_google
    • is that search also adjusted to DDG in the theme? If not, that should be fixed too
  • js.google_search
    • that looks like it’s editable to put in DDG directly, not sure how that’s related
Is that it?
Okay, I’m writing this down, because 404 handling in Discourse is weird. Try this link on for size:
https://meta.discourse.org/nonexistant-page
If you open it in a new tab, you’ll notice that your user menu (the one in the upper-right of the page) doesn’t render. In fact, the Discourse Ember app doesn’t get loaded at all in this case. It’s being rendered by the Rails server following app/views/exceptions/not_found.html.erb
Obviously, if you click the link directly in this page, the Ember app remains resident. Try hitting the link with a .json at the end, and instead of sending the app a full 404 page, it sends an HTML fragment, with the heading and stuff removed, which the Ember app just plops into place.
Oh weird. But if that’s less trivial to fix, at least it can be documented and the easier parts all fixed. Thanks for working on this!
https://github.com/notriddle/discourse-duckduckgo-search/commit/17c849c5b8c22476720a07ee7ebfa4536feecedc
Added a commit to do the form rewriting to make the 404 page work, both within and without the Ember app.
Great! So the only remaining thing is to document (probably both here and at the repo README) the confirmed list of text items theme-users will need to customize in the admin UI?
I got this working, but it’s a little strange to have the page-not-found version start with the form using site:xxx… with no search term alongside that. Maybe that’s as good as it gets, but it would be ideal if it were feasible to get the text of the URL after the TLD for the not-found page and use that as the default search before the site: part…
Given
Google is no longer used at 404 pages. So, this theme probably needs updating to leave 404 pages alone, let them be the regular internal search as is now standard.
Discourse is still using Google for extra searching when internal searches fail though. So, for that, this DDG option still applies.
It wasn’t actually breaking anything, but I did go ahead and revert it. It also made the code simpler, since I can just replace the template again.
https://github.com/notriddle/discourse-duckduckgo-search/commit/39e5501c35f2b73dd3eb9a7977de0c472d85711c
is there any reason Google is still the default for Discourse when extra searching occurs? DuckDuckGo is more in tune with the mindset of Discourse than Google is.
I second this, there is a current workaround?
Could be used with Discourse AI too :slight_smile:
This theme component is the workaround.
I hadn’t seen this topic and didn’t know about the theme component, so I just got rid of the whole Google search thing entirely… I’m reluctant to add yet another unofficial theme component now though. It would be good if the default were DuckDuckGo or if there were a site setting.
…that allowed changing the provider, or removing this fallback search suggestion altogether.
In the meantime, how did you “remove the search thing entirely”? Presumably, you made a theme component, but can you share the actual code here (so I don’t have to go figure this out myself)?
I forked it and changed the URL. The general standard should be to leave it empty and allow the user to change it.
That’s how marketing deeply works, through social engineering on finest levels.
I’ve pushed an update to use a plugin outlet, but this needs the outlet added to Discourse itself.
https://github.com/discourse/discourse/pull/31733
