Eerste onderwerpcreatie vergemakkelijken door 'esc' in de editor te vervangen door tekst met meer begeleiding
The discussion revolves around improving the user experience when creating a new topic in Discourse by making the ‘esc X’ prompt more intuitive for non-technical users. guidoleenders notes that the current ‘esc X’ label can be confusing and suggests replacing it with clearer text like ‘See Preview’ or ‘Close to see Preview’ to guide users. Mevo expresses concern that associating the ‘X’ with opening a preview may be misleading, as ‘X’ typically signifies closing. JonathanShaw agrees that the overlay UX is non-standard and not intuitive. In response, guidoleenders revises the suggestion to use ‘Close to see Preview’ to better align with user expectations.
In Discourse, the initial view of a topic when entering text in the composer includes a list of resembling topics:
In the top-right corner it says ‘esc X’. For non-technical users, the meaning of ‘esc’ can be confusing. When clicked, it always shows the preview. First-time non-technical users typically do not use the preview mode therefore we have found in a few tests.
Suggestion is to:
  • Make ‘esc’ translateable (now taken from CSS).
  • Replace initial text by something like ‘See Preview’.
In our deployment we have adapted the CSS to read: “Click to see preview”. It is not translateable (we use a lot of Dutch), but nonetheless provides more guidance.
In principle, something bothers me a little: You click to close something which is on top of the preview.
I don’t like too much the idea of associating the “X” in the right corner with anything else than CLOSING. Here, you’re suggesting to associate it with a result: Seeing the preview. In practice, it’s what is indeed going to happen and it seems to have the advantage to be of being clear in what will happen, but still.
At least “Close” instead of “click”, then.
“Close to preview” might be OK. The whole UX of a message overlying a preview pane is not standard or intuitive.
Agree. Adapted suggestion:
Suggestion is to:
  • Replace initial text by something like ‘Close to see Preview’.
