Edited htaccess and now im getting discourse sso expired error
I am using my wordpress site to function as an SSO client. Meaning Discourse authenticates all users (logins, registrations, etc…).
After editing my htaccess file to increase my wordpress site speed. I noticed that the following error started to appear when I try and login “discourse_sso_error=expired_nonce”.
I looked through the forum and found out that the issue is probably because of the htaccess file. Although, I want to know what exactly I should remove from it. So that I can keep my site speed as fast as possible while also solving this problem.
Here is the code in htaccess
    # BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
# BEGIN WordPress
RewriteEngine On
RewriteBase /
</IfModule>
# END WordPress
AddOutputFilterByType DEFLATE text/html
AddOutputFilterByType DEFLATE text/css
AddOutputFilterByType DEFLATE text/javascript
AddOutputFilterByType DEFLATE text/xml
AddOutputFilterByType DEFLATE text/plain
AddOutputFilterByType DEFLATE image/x-icon
AddOutputFilterByType DEFLATE image/svg+xml
AddOutputFilterByType DEFLATE application/rss+xml
AddOutputFilterByType DEFLATE application/javascript
AddOutputFilterByType DEFLATE application/x-javascript
AddOutputFilterByType DEFLATE application/xml
AddOutputFilterByType DEFLATE application/xhtml+xml
AddOutputFilterByType DEFLATE application/x-font
AddOutputFilterByType DEFLATE application/x-font-truetype
AddOutputFilterByType DEFLATE application/x-font-ttf
AddOutputFilterByType DEFLATE application/x-font-otf
AddOutputFilterByType DEFLATE application/x-font-opentype
AddOutputFilterByType DEFLATE application/vnd.ms-fontobject
AddOutputFilterByType DEFLATE font/ttf
AddOutputFilterByType DEFLATE font/otf
AddOutputFilterByType DEFLATE font/opentype
# For Olders Browsers That Can’t Handle Compression
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4\.0[678] no-gzip
BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
<IfModule mod_expires.c>
# Enable expirations
ExpiresActive On
# Default directive
ExpiresDefault "access plus 1 month"
</IfModule>
# My favicon
ExpiresByType image/x-icon "access plus 1 year"
# Images
ExpiresByType image/gif "access plus 1 month"
ExpiresByType image/png "access plus 1 month"
ExpiresByType image/jpg "access plus 1 month"
ExpiresByType image/jpeg "access plus 1 month"
# CSS
ExpiresByType text/css "access plus 1 month"
# Javascript
ExpiresByType application/javascript "access plus 1 year"
Above code looks incomplete. Also, below one looks wrong.
ExpiresActive On
# Default directive
</IfModule>
It will set max-age for 30 days for everything, it will cause terrible browser caching issue with your site. Please avoid. Rest your choice!
  • Instead of using manual .htaccess code, just use one cache plugin and it will handle all common stuffs in better way.
  • Or, implement a CDN to handle GZIP and Browser Cache which you are trying to do using above codes.
2 curtidas
Este tópico foi automaticamente fechado após 2225 dias. Novas respostas não são mais permitidas.
