Editing a guide results in "internal server error"
Hi. A guide has been found to say “internal server error” when being edited. Can this be fixed?
Guide
Hey there, welcome to meta.
“Internal server error” is a very generic error, but you can check your site’s logs @ /logs to see if there are any hints to why editing doesn’t work.
I’m not an admin but a moderator said “Nothing comes up in the logs.”
Unfortunately, without sufficient information in logs it is not possible to help solve your issue. One thing to note is that if you open your browser console, pretty much all the images are not loading (404-ing).
You may also try safe mode, but it is unlikely that will allow you to edit the post.
